I'm selling a custom turbo piping setup for an AE92. Will come with piping, couplers, and Mishimoto intercooler. There is a fitting that will need to be blocked off if not used. It was suppose to be for the Megasquirt PNP sensor needed to run a MAP setup. To fit, you will need to cut a portion of metal on either side of the radiator. $350
I also have a 2.5 inch downpipe with flex pipe and a v-band setup; the length goes about 3/4 down the exhaust tunnel - $150
Megasquirt PNP (MS DIYPNP V1.5) (unbuilt) will bring hardware to build, plugs to connect to your laptop, sensor for motor to eliminate AFM;- $300
4age ebay turbo manifold - $50
Small T3 Rebuilt Turbo - $200
7MGTE Injectors (All 6) - $80
Tial Wastegate with 7 PSI spring (Installed, never used) - $150
Powdercoated 4age Valve Covers with breather holes and AN fittings - $125
Authentic SARD FPR (Installed for placement, never used) with -6 AN fittings - $80
20 Valve tranny plate to block the front starter hole and open the starter hole in the rear - $40
https://www.dropbox.com/sh/apghi1xvjnop ... 2x-Ka?dl=0
Faster responses through email - t_byron239 at yahoo dot com
FS: Turbo Setup Part Out for AE92 & 4age Related Parts
truenorican
