This is a set of 2 TRD front strut top mounts (new old stock). This may be the last set of these you'll ever come across, at least in new condition, as they and virtually all other TRD parts for our car have been discontinued for years now. Both come in their original plastic baggies.
Both TRD and OEM front strut tops use a significant amount of rubber to isolate the upper section from the lower section of each mount. The rubber used in the TRD top mounts is significantly harder (higher durometer) than that used on the oem mounts. The harder rubber used in the TRD mounts helps provide more accurate steering input, and suspension alignment (by eliminating flex), especially as the the mounts age, in comparison to oem mounts.
For someone looking to finish off a really special car these would be a great addition.
These will fit all '85-89 MR2's, but to fit the '85-86 models you must either drill an additional bolt hole for the 4th stud on the front mounts, or press out the 4th studs on those two mounts.
SOLD, plus shipping to the lower 48 states;
Please IM me (or email: reswcbym@frontier.com) if interested, or have any questions;
TRD top mounts NOS - front-top
TRD top mounts NOS - front-bottom (extra grease cleaned from one mount and not the other)
TRD top mounts NOS - front-in bags
