Possible Turbo Corolla Part Out Tampa,FL
Toyota97
Postby Toyota97 » Sat Apr 13, 2013 4:29 pm
I might be parting out my build since I can't find a buyer to take it as a whole and I'm not lowering the price anymore. If I can find someone to buy the motor then I go ahead with parting out the car.
Car runs needs exhaust finished and a tune. Do not recommend driving the car without it being finished.
$2500 firm for everything
Fresh 20v Blacktop Block with Oil Squirters
4afe Head
HKS 2mm Headgasket
4AGZE Pistons
4AGZE Rods
20v Blacktop Crank
20v Blacktop Flywheel
ACT 4 Puck Clutch
Techno Tuning Lightweight Crank Pulley
Turbo Supra Injectors 440cc
ARP rod, main, flywheel and head studs
HKS Oil Filter
TOGA Race Bearings Main and Rod
T04E Turbo
Tial 38mm wastegate
Custom Turbo Stainless steel Manifold
Custom 2in Intercooler Piping
Apexi Intercooler
Greddy Type RS BOV
Oil catch can installed yet
Tomei Fuel pressure regulator with Tomei adapter for fuel rail
TOGA HV Oil Pump
Walbro 255 Fuel Pump
OBX-R Radiator Hoses
VMS Racing 10mm Spark plug wires
OBX High Performance Racing Iridium Spark Plugs
Aem tru boost and Wideband
STRI Oil Pressure Gauge
Short Shifter
3in Stainless Steel downpipe
Apexi SAFC II
Semi wire tuck
Advan replicas good tires
Rear Disk Conversion
Custom shaved valve cover with rouge status theme
RedBull Boost Gauge Custom
Gauge Cluster with Tach
Racing steering wheel with quick release
Brand New Battery with Warranty
Arev 1'' wheel spacers
New Rear Main Seal
New Timing Gear and Crank Bolt
New Timing Gear Covers
New Toyota Timing Belt
New Timing Belt Tensioner
New Water Pump
All New Gaskets
All New Belts
All Royal Purple Fluids
Most all new nuts and bolts
Viper Alarm System with GPS Tracking Not installed yet
every bolt is torqued to spec;)
Again, in order for me to part out the car I must find a buyer for the motor. Feel free to ask any questions. Thanks for veiwing
rocketbunny86
Re: Possible Turbo Corolla Part Out Tampa,FL
Postby rocketbunny86 » Wed Apr 17, 2013 6:53 am
how much would shipping to Houston Texas 77084 ?
Toyota97
Postby Toyota97 » Wed Apr 17, 2013 8:32 pm
Shipping on what?
The motor is going to be parted out. I'll being posting everything Sunday and also will be listing things on eBay so I can get this stuff moved asap. I won't be shipping the crankshaft, block, or transmission. That stuff will be sold locally unless buyer really wants to pay shipping.
I'll be starting the official part out thread this weekend.
Thanks for viewing
kaosboss
Postby kaosboss » Tue Apr 23, 2013 4:33 pm
Any luck with the price list
Toyota97
Postby Toyota97 » Tue Apr 23, 2013 7:43 pm
Yes I currently have over ten auctions on eBay
My user name is trsfiziks on eBay
As far as the rest I'll keep everyone posted. I can not send PM's to anyone nor reply cause i just re-registered. I haven't been in her since it was the old club4ag
Check out my auctions
kaosboss
Postby kaosboss » Wed Apr 24, 2013 3:05 am
Is this on ebay usa? Was not finding your name.
Rogue-AE95
Postby Rogue-AE95 » Wed Apr 24, 2013 12:41 pm
What GZE pistons are they? 8.1 or 8.9? Any issues with the block, crank, pistons, or rods? (I'm like 45 minutes from Tampa.)
Toyota97
Postby Toyota97 » Thu Apr 25, 2013 12:24 am
That's weird, trsfiziks is my user name on ebay. I'm sure I'm not allowed to do this but...
Tru Boost
http://www.ebay.com/itm/140959057587?ss ... 1555.l2649
Wideband
http://www.ebay.com/itm/140959074453?ss ... 1555.l2649
Apexi SAFC 2
http://www.ebay.com/itm/140959103221?ss ... 1555.l2649
Turbo Toyota Supra Injectors 440cc low impedance
http://item.mobileweb.ebay.com/viewitem ... 4071079301
HKS Oil Catch Can
http://www.ebay.com/itm/140959135349?ss ... 1555.l2649
Crown Royal Shift boot
http://www.ebay.com/itm/140959138105?ss ... 1555.l2649
Baller Oil pressure Gauge
http://www.ebay.com/itm/140959176880?ss ... 1555.l2649
Tomei Fuel Pressure Regulator with AN hose and adapter for your Toyota Nissan or Subaru
http://www.ebay.com/itm/140959581937?ss ... 1555.l2649
93-97 Toyota Corolla Gauge Cluster w/Tach AE101 AE100 AE102 JDM TRD
http://www.ebay.com/itm/140959699890?ss ... 1555.l2649
Authentic Walbro GSS342 255lph Fuel Pump AE101JDM Toyota Corolla
http://www.ebay.com/itm/140959712627?ss ... 1555.l2649
Custom RedBull Boost Gauge JDM Turbo 4AGE AE101
http://www.ebay.com/itm/140959704128?ss ... 1555.l2649
JVC KD-R900 Dual USB/CD/MP3 In Dash Alpine JL Kicker AE101 93-97 Corolla
http://www.ebay.com/itm/140960713132?ss ... 1555.l2649
As far as the block, crank, pistons and rods, this is a picture before all the stuff got installed. I'm quiet sure this stuff is still in the same shape as when I put them in saying I only ran the car for a total of two minutes if that. Just to see if it would fire up. I wanna say the pistons are 8:9 I can't remember. check out the pictures.
I think it's safe to say this stuff is in great condition.
I need to still pull out the motor and strip it down so everything can be sold. I plan on going to do that this weekend and starting an Official part out thread. I'll keep everyone posted.
Rogue-AE95
Postby Rogue-AE95 » Thu Apr 25, 2013 8:32 pm
Bottom end does look good. Was it overbored? Any machine shop work done to it? Can I ask why it wasn't run, other than for those few minutes?
Toyota97
Postby Toyota97 » Fri Apr 26, 2013 2:07 am
It's standard bore size 82mm and yes it's had the mains line bored(standard size) to assure everything as straight, cyclinders honed, dipped and cleaned,new freeze plugs. I have receipts for everything. work was done at Rays Machine Shop in Tampa.
I moved from a house to an apartment and had no place to finish the car, thats y I posted it for sale and then I decided to part out the car because I have almost triple my asking price in the car and the only way to get most my money back was to part everything out. It was only run for a short time cause I just wanted to see my car run before it was gone. I'm not the type to just get it running and drive it. The car still needed a tune, paint, coilovers, and more JDM ish in order for me to be happy enough to drive it daily. It ran, I built it and that made me happy.
Here's my number if you or anyone has serious inquires about parts they want.
8134143863
Thanks
