FS: Rebuilt 4AG hi-comp motor
Posted: Tue Feb 26, 2013 8:42 pm
by Oliver
Hi everyone. I'm selling a newly rebuilt 4AG motor with 0 miles and the specs are below. The engine is located in Van Nuys, CA, no shipping at this time. Asking $1800 and you can contact me at
OSanchez1026@GMail.com.
High-comp bottom end
-new freeze plugs
-honed
-new rings
-new bearings
-comes with oil pump
Large port head
-3 angle valve job
-new seals
-shims replaced as needed
Re: FS: Rebuilt 4AG hi-comp motor
Posted: Wed Feb 27, 2013 12:36 am
by Esenpai
Large Port ≠ high comp.
You got yourself a low comp there my friend high comps are small ports.
Posted: Wed Feb 27, 2013 3:12 am
by ronny
It's a custom setup. Hybrid
Hi comp block with big port.
Look at the return line on the block
I had this setup before. It's awsome with 72 cams
Posted: Sat Mar 02, 2013 7:42 am
by Oliver
PMs and emails responded.
Posted: Tue Mar 05, 2013 2:14 pm
by Oliver
Up there!
Posted: Thu Apr 04, 2013 8:27 am
by Oliver
Bump!
Posted: Mon Apr 22, 2013 12:12 pm
by Oliver
Up!
Posted: Sat Apr 27, 2013 10:43 am
by Oliver
PMs and e-mails replied. Bump!
Posted: Fri May 10, 2013 2:35 pm
by Oliver
Friday bumpage!
Posted: Fri May 10, 2013 9:02 pm
by mgwooley
This was my original plan for my bigport... decided for 20v instead. Glws man!
Posted: Thu May 23, 2013 10:56 am
by Oliver
Up!
Posted: Wed Jun 19, 2013 7:45 am
by Oliver
All e-mails responded.
Posted: Wed Oct 30, 2013 1:21 pm
by Oliver
Up.
Posted: Fri Nov 01, 2013 11:16 am
by Oliver
New price: $1400.
Posted: Sat Nov 23, 2013 2:05 pm
by Oliver
Up!
Posted: Tue Dec 10, 2013 10:01 am
by Oliver
Thanks for the e-mails and calls yesterday, guys. As I mentioned, the engine comes with a 1 year warranty from the builder! Let's get this sold before Christmas!
Posted: Tue Dec 10, 2013 2:35 pm
by ae86sr20de
Sorry for this stupid question. Been having problems finding a smog hook up on my Corolla. I honestly dont know much about the 4ag motors. Will this motor pass smog? Im getting tired of trying to smog my AE86 with SR20 swap. Thinking about going back to stock. So I can drive my car again.
Posted: Tue Dec 10, 2013 5:41 pm
by DrAE86Toreno
Hmmmm I might consider this n just swap my cams, underbucket shim n carbs...how far r u from SD? I just arrived on west coast so still learning
Posted: Wed Dec 11, 2013 1:01 pm
by Oliver
Thanks for the emails and inquiries.
AE86SR20
This is a direct drop in and will pass visual and smog as long as you have all of your smog equipment installed. I have the same setup in my coupe and recently passed the new Star Smog tests.
DrAE86Toreno
The engine is located in zip code 91406, Van Nuys, CA.
Posted: Wed Dec 11, 2013 6:06 pm
by mrkona
This seller is the real deal so if you need a great engine buy this one !
Posted: Wed Dec 11, 2013 7:51 pm
by DrAE86Toreno
hmm 2 hrs plus...not bad...ill email you in the next few days or so
Posted: Sun Dec 22, 2013 8:47 am
by DrAE86Toreno
How is this type of engine setup? U say you have it on your coupe...is it pretty good? If I get it I'll b adding toda 288 w/ 10.5 lift ...underbucket shims n mikuni 44...I'd just like a nice street setup to have fun with
Posted: Tue Dec 24, 2013 10:16 am
by Oliver
DrAE86Toreno wrote:How is this type of engine setup? U say you have it on your coupe...is it pretty good? If I get it I'll b adding toda 288 w/ 10.5 lift ...underbucket shims n mikuni 44...I'd just like a nice street setup to have fun with
The hicomp bottom is a vast improvement and the engine response is very noticeable. Your set up is NOT good for street as the 44 Mikunis are too large and your choice in cams is too aggressive. You won't get the bottom end response and useable power at the low end that you need for street use and will be a dog to drive, trust me on this. For street, I strongly recommend you go with 40mm Webber carbs and less aggressive cams, around 262 w/8mm lift like HKS, Toda Poncams, Web, or Colt.
Your set up, with my hicomp engine, is better suited for track use where top end response and power matters more. You won't have any fun on the streets with the set up you called out as it will most likely bog off the start, unless you rev it really, really high, which will probably burn your clutch.
Posted: Tue Dec 24, 2013 1:33 pm
by DrAE86Toreno
Gotcha...yeah I'm pretty much running what I described...I dnt make power until 4k to above...i don't drive the car everyday so I don't mind I just need a new motor or either rebuild mine...I'm not trying to spend on new cams n carb setup that's y...moving to Japan in a year so just trying to do a quick rebuild...I'll hit u up soon hopefully motor still available
Posted: Fri Dec 27, 2013 10:19 pm
by Oliver
Engine is sold!
