FS: Rebuilt 4AG hi-comp motor
Oliver
Postby Oliver » Tue Feb 26, 2013 8:42 pm
Hi everyone. I'm selling a newly rebuilt 4AG motor with 0 miles and the specs are below. The engine is located in Van Nuys, CA, no shipping at this time. Asking $1800 and you can contact me at OSanchez1026@GMail.com.
High-comp bottom end
-new freeze plugs
-honed
-new rings
-new bearings
-comes with oil pump
Large port head
-3 angle valve job
-new seals
-shims replaced as needed
Esenpai
Re: FS: Rebuilt 4AG hi-comp motor
Postby Esenpai » Wed Feb 27, 2013 12:36 am
Large Port ≠ high comp.
You got yourself a low comp there my friend high comps are small ports.
ronny
Postby ronny » Wed Feb 27, 2013 3:12 am
It's a custom setup. Hybrid
Hi comp block with big port.
Look at the return line on the block
I had this setup before. It's awsome with 72 cams
Rays - Project Mu - TE37 club
BLUE MOON / CUSCO
AE86fightclub.com
PM me for Contact
Oliver
Postby Oliver » Sat Mar 02, 2013 7:42 am
PMs and emails responded.
Oliver
Postby Oliver » Tue Mar 05, 2013 2:14 pm
Up there!
Oliver
Postby Oliver » Thu Apr 04, 2013 8:27 am
Bump!
Oliver
Postby Oliver » Mon Apr 22, 2013 12:12 pm
Up!
Oliver
Postby Oliver » Sat Apr 27, 2013 10:43 am
PMs and e-mails replied. Bump!
Oliver
Postby Oliver » Fri May 10, 2013 2:35 pm
Friday bumpage!
mgwooley
Postby mgwooley » Fri May 10, 2013 9:02 pm
This was my original plan for my bigport... decided for 20v instead. Glws man!
Oliver
Postby Oliver » Thu May 23, 2013 10:56 am
Up!
Oliver
Postby Oliver » Wed Jun 19, 2013 7:45 am
All e-mails responded.
Oliver
Postby Oliver » Wed Oct 30, 2013 1:21 pm
Up.
Oliver
Postby Oliver » Fri Nov 01, 2013 11:16 am
New price: $1400.
Oliver
Postby Oliver » Sat Nov 23, 2013 2:05 pm
Up!
Oliver
Postby Oliver » Tue Dec 10, 2013 10:01 am
Thanks for the e-mails and calls yesterday, guys. As I mentioned, the engine comes with a 1 year warranty from the builder! Let's get this sold before Christmas!
ae86sr20de
Postby ae86sr20de » Tue Dec 10, 2013 2:35 pm
Sorry for this stupid question. Been having problems finding a smog hook up on my Corolla. I honestly dont know much about the 4ag motors. Will this motor pass smog? Im getting tired of trying to smog my AE86 with SR20 swap. Thinking about going back to stock. So I can drive my car again.
DrAE86Toreno
Postby DrAE86Toreno » Tue Dec 10, 2013 5:41 pm
Hmmmm I might consider this n just swap my cams, underbucket shim n carbs...how far r u from SD? I just arrived on west coast so still learning
Oliver
Postby Oliver » Wed Dec 11, 2013 1:01 pm
Thanks for the emails and inquiries.
AE86SR20
This is a direct drop in and will pass visual and smog as long as you have all of your smog equipment installed. I have the same setup in my coupe and recently passed the new Star Smog tests.
DrAE86Toreno
The engine is located in zip code 91406, Van Nuys, CA.
mrkona
Postby mrkona » Wed Dec 11, 2013 6:06 pm
This seller is the real deal so if you need a great engine buy this one !
DrAE86Toreno
Postby DrAE86Toreno » Wed Dec 11, 2013 7:51 pm
hmm 2 hrs plus...not bad...ill email you in the next few days or so
DrAE86Toreno
Postby DrAE86Toreno » Sun Dec 22, 2013 8:47 am
How is this type of engine setup? U say you have it on your coupe...is it pretty good? If I get it I'll b adding toda 288 w/ 10.5 lift ...underbucket shims n mikuni 44...I'd just like a nice street setup to have fun with
Oliver
Postby Oliver » Tue Dec 24, 2013 10:16 am
DrAE86Toreno wrote:How is this type of engine setup? U say you have it on your coupe...is it pretty good? If I get it I'll b adding toda 288 w/ 10.5 lift ...underbucket shims n mikuni 44...I'd just like a nice street setup to have fun with
The hicomp bottom is a vast improvement and the engine response is very noticeable. Your set up is NOT good for street as the 44 Mikunis are too large and your choice in cams is too aggressive. You won't get the bottom end response and useable power at the low end that you need for street use and will be a dog to drive, trust me on this. For street, I strongly recommend you go with 40mm Webber carbs and less aggressive cams, around 262 w/8mm lift like HKS, Toda Poncams, Web, or Colt.
Your set up, with my hicomp engine, is better suited for track use where top end response and power matters more. You won't have any fun on the streets with the set up you called out as it will most likely bog off the start, unless you rev it really, really high, which will probably burn your clutch.
DrAE86Toreno
Postby DrAE86Toreno » Tue Dec 24, 2013 1:33 pm
Gotcha...yeah I'm pretty much running what I described...I dnt make power until 4k to above...i don't drive the car everyday so I don't mind I just need a new motor or either rebuild mine...I'm not trying to spend on new cams n carb setup that's y...moving to Japan in a year so just trying to do a quick rebuild...I'll hit u up soon hopefully motor still available
Oliver
Postby Oliver » Fri Dec 27, 2013 10:19 pm
Engine is sold!
