Electromotive TEC-II standalone ECU w/ newest firmware
Posted: Sun Jan 17, 2016 3:11 pm
Electromotive TEC-II standalone ECU was removed from a running Toyota 4AGE 20v Turbo setup. Has newest firmware chip upgrade WT202T2.
Comes with everything pictured, 2-bar MAP sensor, idle control valve, MSD 8.5mm super conductor spark plug wires, crank sensor & mount for Toyota 4AG (wire is cut on sensor, might be able to be spliced), serial cable.
Will need a crank trigger wheel for your application.
This was on a Toyota 4AGE 20v with CT26 turbo but was replaced by a brand new Haltech unit while upgrading.
A MR2 with 20v Turbo setup tuned on TEC-II to 437whp just sold in Chicago a couple months back, so this ECU is definitely capable on a 20v! I mainly upgraded to the new Haltech setup because I got a good deal and wanted to try doing a USB gauge cluster.
http://i.ebayimg.com/images/g/tRQAAOSwa ... s-l400.jpg
$500 shipped within continental US.
