4age silvertop swap stuff & 4a to w5x things
gbogho
Postby gbogho » Sun Dec 06, 2015 12:56 am
I'm selling my silvertop swap to go for a different engine.
The engine is prepped and ready to be dropped in.
The details:
JDM silvertop 4age with good compression on all cylinders
New front & rear main seals
Newly resealed oil pan
New cam seals
New timing belt
Older SQ engineering coolant reroute kit w/ heater
SQ engineering dizzy relocator kit w/ extended wire
SQ engineering lifting bracket
T3 pulleys (crank, alt, and water pump)
Intake plenum modified for RWD use
Complete (uncut) wiring harness
ECU
Toyota gasket set (some of the gaskets are already installed on motor)
Engine ran before torn down for gasket replacement and parts install
various other maintenance parts (unused oil filters, timing belt, and a couple other odds n ends)
$1600 + shipping
TRD 4age header (used) $250 + shipping
CXracing tri-y equal length header, ceramic coated (new) $350 + shipping
OBX 4-1 header (used) $150 + shipping
4a to w5x bellhousing (holes bored/filled to fit block better, mating surfaces milled parallel)
212mm flywheel spin balanced & resurfaced
illegal garage 4a to w5x clutch disc and pressure balanced (spin balanced)
stainless braided clutch slave line
2 throwout arms with bearings and pivots
new clutch slave (might have more than 1)
$650 + shipping
Parts are located in Silverdale, WA
Interest/want pics & serious offers should contact
flarenutwrench510 at gmail dot com
gbogho
Re: 4age silvertop swap stuff & 4a to w5x things
Postby gbogho » Sun Dec 06, 2015 3:41 pm
Willing to trade for 1uz/w58 swap parts
cerumo
Postby cerumo » Tue Dec 08, 2015 4:51 pm
Can you text pictures for cx racing and Trd header to 626 536 0066 please.
83toywagonblue
Postby 83toywagonblue » Wed Dec 09, 2015 6:25 pm
Email
Sent from my SM-N910T using Tapatalk
gbogho
Postby gbogho » Sun Dec 13, 2015 6:04 pm
bumpity bump bump
