Dastek Unichip Type A
Alex170984
Postby Alex170984 » Fri May 22, 2015 7:30 am
Hi all,
I bought this last month with a view to rolling road tune the chip but as I am having to replace 8 inlet valves, I need to raise the cash.
It will require mapping to your ECU (have checked it is compatible to my aw11 ecu, so i'm assuming other 4AGE ECUs will be fine as well.
£110 O.N.O plus delivery.
Cheers
sirdeuce
Re: Dastek Unichip Type A
Postby sirdeuce » Fri May 22, 2015 9:56 am
If it's like the other pieces, Apexi, e-manage etc. it won't work on AFM type ECUs. The JDM, Euro MAP type ECUs use a 0-5v signal and the AFM uses a 0-9v. The aftermarket tended to ignore the AFM type due to it's restriction through the AFM, or something like that. If your unit will work for either you have a piece of gold!
One shot, one kill.
Alex170984
Postby Alex170984 » Wed May 27, 2015 4:21 am
Hi,
Unaware if it overrides the AFM but been told it works fine for my AW11 ECU.
I'll see if I can find out for you.
Alex170984
Postby Alex170984 » Tue Jun 09, 2015 2:04 am
Item has now been SOLD
