SK racing 48mm carburetors + trd manifold Formula Atlantic
AxisZ
Postby AxisZ » Tue Feb 17, 2015 6:32 pm
For sale a set of SK racing 48mm carburetors, 4 spacers that go between the manifold and carbs, trd manifold, and universal sidedraft throttle linkage. Currently have 43mm venturi, 155 main jets, F16 emulsion tubes, 165 air correctors, 55F8 idle jets, 45 accel pump jets. So they're not really setup for a stock 4age. If you have a 7age, or a 4age with O/S valves then these are for you, if not don't expect these to work well right out of the box. A few notes, the trd manifold mounting holes are opened up and have dowels that can be removed. I guess this was done to better line up the manifold to the head when they were both ported. Also one of the mounting bosses on the carb body was rounded off so it was repaired with Devcon which can be seen in one of the pictures. Looking to get 700$ shipped in the continental USA or best offer.
Ish88
Re: SK racing 48mm carburetors + trd manifold Formula Atlant
Postby Ish88 » Thu Mar 05, 2015 2:56 pm
are they still available ? if so Email me Ismaels88@yahoo.com . thanks
saiGone
Postby saiGone » Tue Mar 10, 2015 8:07 am
Nice! GLWS
If you don't have any luck, try the Carb Group
https://www.facebook.com/groups/398244027001492/
