Hi All,
I'm selling my MegaSquirt N Spark Extra with Plug and Play ECU directly into your stock AE86 engine and dash wire harness. I used to run this on
my JDM Hicomp Smallport engine and felt a huge difference in throttle response and power. I had plans using this system to run ITBs, but my
drifting days are over and I just DD my car now, so its time to sell it. Will come with MSNS Extra ECU, Custom plug and play ECU harness to AE86, Serial to USB connnector, CD software (MegaTune, (you could probably find the latest software online) and some print outs with useful information. If you want to run this on your stock 4age, you can, all you have to do is:
1) Bypass the Fuel pump cutoff in the AFM connector. ( Connect pins 2 and 5),
2) Install a IAT (Intake Air Temp) Sensor into your intake pipe and connect it to 2 wires in your AFM connector
3) Run the Vacuum line into any Vacuum hole in the intake manifold for the map sensor in the ECU
Price is $350 OBO picked up in Socal, 626, Alhambra, or $375 OBO shipped in the US. Email me at hildebrand168@yahoo.com. Here's some pix:
F/S MegasquirtNSpark Extra w/Plug & Play SOLD!!!!!
Re: F/S MegasquirtNSpark Extra w/Plug & Play ECU into your A
What version MS is this?
It is Megasquirt 1 version 2.2, fully assembled, Firmware type is
MegasquirtNSpark Extra.
