Sold! $150 OBO Plus shipping Sold!
More Pictures
Fidanza Flywheel 212mm
Picked this up from Jared on the other forum. The friction area, of the flywheel, was replaced and has not been used. I have a matching stock used disc and pressure plate you can have for free with this.
SOLD $170 OBO plus shipping SOLD
https://lh4.googleusercontent.com/-7FCoOF1IsNk/UaYwCbXZI1I/AAAAAAAAB-0/DWgq32dlOCk/w1008-h672-no/Fidanza+Flywheel.jpg
4age 3-rib Short block unassembled. This is the lightest, to my knowledge, production rotating assembly available for the 4age. The motor came out of a running car, got about 35 mpg, had 200k miles on it. I have everything organized and all of the bolts in labeled bags. I plastigauged and recorded the results of all the bearings while disassembling. They were all within the factory tolerances. I would recommend getting everything checked out by a machine shop. At a minimum replace all of the bearings and head bolts. Piston #3 has a tiny piece missing on the top outer face.
Sold! $75 OBO picked up Sold!
More Pictures Here
4age Bigport head off of the running motor from above. Comes with early bigport cams which have a little more lift. Completely stripped down except for valve guides. I have records of what shims came from what bucket and what the clearances were. The shims are in small labeled bags To my knowledge, the ports have not been touched. Needs valve seals at a minimum. The head, without the valve train, was cleaned via a spray wash cabinet and some light blasting with walnut shells. Comes with the blue valve covers. Cylinder Head 1 in the pictures.
Sold! $70 OBO Plus Shipping Sold!
More Pictures
4age Bigport head I used to practice some porting on. One of the chambers has the shrouding removed. I bumped into the exhaust port seats a few times on that chamber with a rotary tool, but I could only find scuff marks. Four of the valves have been shaved down. A few of the valves had a little rust near the seating section. The shims are still in the buckets they came from. After removing the valvetrain, the head was cleaned via a spray wash cabinet and some light blasting with walnut shells. Comes with the standard color valve covers. Cylinder Head 2 in the pictures.
Sold! $30 OBO plus shipping Sold!
More Pictures
Shortblock and both heads Sold! $100 OBO Picked Up Sold! Will through in whatever else you want/need that came off the motor. Freight for this is going to be around $150 so I would rather not ship.
Shortblock and Early Bigport Head Sold! $90 OBO Picked Up Sold!
4agze Knock Sensor $65 OBO shipped Cont US
Working Cruise control computer, and the two firewall mounted pieces. $45 OBO shipped Cont. US
Prothane Steering rack and front sway bar (18mm) bushings Brand new in box $20 shipped Cont US
If you see any other parts you want in the pictures let me know. I will be updating this post and thread with prices for the other pieces shortly.
All Pictures
Unfortunately I don't do paypal. I can do amazon payments (fastest way to do it), a USPS money order, or a Cashier's Check/Bank Check. Will drive a reasonable distance for the right deal.
I have had issues with paypal, to say the least, and scammers from ebay taking advantage of their automatic ruling system for claims.
It's pretty easy to setup an amazon payment account if you buy from amazon. My username is moldspectors@gmail.com . https://payments.amazon.com/sdui/sdui/index.htm
