2-26-2013 - All Parts Have Been Sold - Thanks
I have the following 4A GE 20V parts for sale. All parts are from a SIlvertop engine though many (such as the starter) will also fit a Blacktop. All parts are used but serviceable except as noted. Check back as I will add more parts over the next several days:
E-Mail for pictures or further info - jetski983@aol.com
All below prices include shipping to a US location:
1 set of Silvertop injectors rebuilt and flowtested by RC Engineering. Never used after service. I have the flow test data. - $65.00
1 starter - $30.00
1pair - stock crankshaft and alternator pulleys - $20.00 - SOLD
1 oil pump - $15.00
1 OEM clutch including pressure plate and disk - Disk has plenty of life left - $50.00
2 - OEM flywheels - $35.00 each (heavy - expensive to ship)
1 - OEM fuel pressure regulator - $10.00
1 - NEW OEM ring set - standard size - $40.00
1 - VVT solenoid - $15.00
1 - Silvertop ECU - $75.00 - SOLD
1 - Set Silvertop OEM camshafts, intake cam has the VVT pulley - $100.00
1 - Set (20) Cam lifter buckets - $40.00
1 - lot of 40 various sized cam lifter spacers (anyone building a Silvertop or Blacktop engine needs these!! - $60.00
1 - Silvertop intake manifold (bare) - $30.00
1 - Silvertop/Blacktop block including main bearings, crankshaft, oil pump, rear seal carrier thermostat housing and water outlet pipe. Block was cleaned in dip tank and freeze plugs replaced, Oil plugs removed and galleries cleaned, main bearings align honed and deck trued. Main bearings are new and main bolts are ARP. - Price dependent upon delivery method - E-Mail to discuss
1 - Set of 4 Silvertop standard size pistons and rods. Pistons have been coated by Swaintech IE: Teflon on skirts, thermal barrier coating on crown. Big end bearings are new. Big end bolts are ARP. Pistons were run for around 5 races after coating. Rings were new prior to installation. Bearings have not been run - $120.00 - Will fit the above block..
1 - Set Silvertop OEM headbolts/washers - $25.00
More to follow!!
4A GE 20V Engine Parts For Sale - Updated 1-28-13
Re: 4A GE 20V Engine Parts For Sale - Updated 1-28-13
Do you have a head??? It can be damaged(cheap???)...
Can you PM me regarding the ECU? I'm wondering what the part number is on yours.
civicdrifter
Hey bud needing vvt solenoid shipped to 34743. LMK. Oh do you have 20v downpipe.. very interested thanks.
ed.
ed.
New oem ring set for $40, is that a ST piston ring set? If so I'll take it.
My turd of an 86
20v swapped 86 write-up
My turd of an 86
Do you have waterneck, igniter or coil pack?
EddieNanakase
I'm looking for the oil dip stick, if you have it, how much total for part and shipping to Chicago IL 60609 ?
EddieNanakase
Well, do you have the engine's oil dip stick for a Silver Top (Black Top is probably the same)?
daveh wrote:2-26-2013 - All Parts Have Been Sold - Thanks
Looks like that's a no...
Communications lacking
My turd of an 86
My turd of an 86
YOu never instAlled those injectors you got back from rc injection did yOu and do you have a picture of the flow chart?
