white 1981 kp61 starlet
new everything, all new brake compents front rear everything, new wheel bearings all round, new diff bearings, wheel seals, new ebrake cables, new timing belt
Phantom grip LSD(limited slip differential kit)
T3 4 links
T3 Tie Rods
T3 sway bar setup with other tie rod and control arms
T3 aluminum Pulley set gold(water pump, alternator, crank)
Aftermarket Cam Gears
BC Ae86 Coilovers
4age header flange mild steel 16v or 20v
Custom fab Aluminum exhaust with unubtainium muffler
Custom Aluminum driveshaft
Anodized black gold valve covers
1989 7 rib 4age 16v
Ford Escort EDIS with plugs and crank sensor
New spark plugs NGK
New fuel Filter(high flow aftermarket)
New walborou external fuel pump with lines
Used Fuel pressure reguator(aluminum) with briaded hoses
4agze injectors(used)
new motor mounts
new tranny mount and a used one
T3 ITB ADAPTER WITH SILVERTOP ITBS AND GOLD T3 VELOCITY STACKS AND NEW TPS SENSOR
Megasquirt 1 ecu and harness
Crank trigger wheel T3
Quantum auto 6 puck feramic unsprung clutch
new pilot bearing
Quantum Auto custom 4age pressure plate with 20% increased clamp force over stock
8 pound cromoly flywheel
ARP flywheel bolts
Evac scavenger kit
Rear axle braided brake lines
Braided front brake lines
Braided clutch line
New alternator, starter, and belt
New brake and clutch master/slave cylinders
New Multicore Wireing all round
New light bulbs
Custom front suspention link & tie rods
1 extra manual rack
1 celica ae86 acxle pumpkin with open diff
1 ae86 axle housing
civic radiator aluminum
new water pump
new hoses
CeliSupra wheels with new falken performance tires 185/60/r14 with center caps(3 extras!!)
Aluminum wheel spacers(ichiba)
T50 tranny thats in fantastic shape from my old sr5 rolla
Aftermarket steering wheel, and adapter
Oil catch can(aluminum)
Strut tower bar T3
Hydraulic Clutch Coversion using civic clutch master and resuvuar
Honda Civic Battery(new)
Aluminum Battery Box
Spare tire included
Fresh synthetic gear oil for diff and tranny(zero miles on it)
Fresh engine oil(zero miles on it)
New lugs and lug nuts
Recaro spg bucket seats(red)
And some extra goodies( little extras of spare parts)
yeah not built on the cheap
selling for about 35% what i put into it
254-319-5943 text call whatever, semi negotable on price
ill give you the finer details if u call so just give a ring, these are old pics
https://post.craigslist.org/k/fFKxWSSW4 ... ?s=preview
4age starlet (part out possible) or total sale, florida
rumsawatti
Re: 4age starlet (part out possible) or total sale, florida
cant see the pics, but if you decide to part, im interested in some stuffs glws
sent you a pm for more pics and prices... thanks.
skatenfish
still got the starlet? are you parting anything off the starlet? id like to have some of those suspension parts on my starlet
sent you a pm quite some time ago but no answer...
