Socal Clean Title 1985 Gts Hatch parting out!
cerumo
Postby cerumo » Wed Aug 02, 2017 10:48 am
Lots of parts for sale so ask if you need anything. Price is OBO.
Prefer text at six two six-five three six- 0066
$350 Brand new Corolla GTS Oem Catback exhaust
$800 Brand New Apexi Hybrid Megaphone exhaust
$250 1985 GTS Hatch bay harness
$200 1985 GTS Rear Hatch harness
$400 GTS Zenki engine harness.
$350 Like New Fortune Auto 500 adjustable rear shocks. Put 50 miles and took them off.
$250 Megan rear adjustable shocks.
$1000 Resurfaced and rebuild Low Comp 4age 16v head with brand new Tomei 268 exhaust and intake cams.
$100 Red top injectors
$150 250 cc injector for Oem harness to use with 4 AGE 16v Hi comp motor.
$140 T3 Pan hard rod.
$160 Battle Version Pan hard rod.
$250 T3 Traction brackets and Lateral rod drop mount.
$1800 1985 GTS rear differential assembly, completed rebuild with all new parts within 1000 miles
Weir Performance 4.3 ring and Pinion with Koyo bearings, Tomei 1.5 way lsd, Toyota brake pads, Toyota brake cables, re-manufactured brake calipers, and Goodrich braid brake lines, Koyo axle bearings and Toyota axle seals.
$350 Used Brian Crower 280 exhaust and intake cams
$350 500 miles resurfaced light weight oem black top 20v flywheels and exedy clutch.
$200 Silver Headlight assembly
$120 Good working Gts Heater Core
$200 GTS rear seat
$120 Front seat belts
$100 Rear seat belts
$150 GTS rebuild distributor
$250 GTS Intake manifold assembly with good working Idle air volume control valve.
$160 Gts K&N intake
$150 Good working mass air flow meter with intake tube
$150 Igniter with new MSD Blaster 2
$100 brake booster.
$200 Front and rear carpets.
$250 AE86 cracked dash.
$450 Completed rebuild manual rack conversion with new inner and outer tie rods, brackets, u joint and intermediate shaft.
$150 True AE86 manual steering column with key.
$300 Gts hatch rear wing
$100 Speedo cable
$100 GTS clutch hard line
$80 Aisin clutch master cylinder.
$40 Gts Gas Pedal
$240 Cusco rear 3 points strut bar.
$120 Cusco front tension rod arm bar.
$1300 Brand New Stance Coilovers with Spindles.
$350 TRD 5KG Rear Springs
$300 Trd 8 ways adjustable rear shocks
$150 Stock Hi-Comp intake manifold. Unmodified.
$120 Brand new Toyota Corolla GTS cooler reservoir tank.
$120 Bran new Toyota Corolla GTS engine mounts.
$120 Brand new Toyota Corolla GTS front and rear brake pads.
$120 Brand new Toyota Corolla GTS acceleration cable.
$150 New Corolla GTS Re-manufactured alternator.
$150 New Corolla GTS Denso Re-manufactured starter.
$100 valve covers
More parts!
6-two-6 five-three-6 zero-zero-66
sja4ag
Re: Socal 85 Gts Hatch part out!
Postby sja4ag » Thu Aug 03, 2017 3:03 pm
heater core? didnt see it listed but thought id ask
1986 coupe, 20v blacktop -- grippy boy
1985 hatch shell, x2 20v silvertops + a lot more goodies -- $2500 (msg me if you want details)
basilss
Postby basilss » Mon Aug 07, 2017 10:52 pm
AC Idle up VSV available?
Road 2 roku
Postby Road 2 roku » Wed Aug 09, 2017 1:02 pm
Contacted you about a cluster, still waiting on reply.
Road 2 roku
Postby Road 2 roku » Sat Aug 12, 2017 6:57 pm
I have tried contacting you, but rarely receive replies.
cerumo
Re: Socal Clean Title 1985 Gts Hatch part out!
Postby cerumo » Thu Oct 25, 2018 1:51 am
Back for more....
Jafet
Postby Jafet » Tue Nov 06, 2018 9:47 pm
By any chance do you have lower control arms?
Ita Racer
Postby Ita Racer » Tue Nov 13, 2018 5:49 pm
I would care to buy the gear box. Can you tell more about the condition. The rebuild. How much for shipping. Please reply
85 AE86 Race Car
91 Supra non turbo
96 Celica convertible
2006 4 Runner
cerumo
Postby cerumo » Wed Jan 09, 2019 6:50 pm
Updated sold parts!
jungle168
Postby jungle168 » Sat Feb 02, 2019 8:46 pm
Would you happen to have any interior pieces?
Dusk. Until the Sky Crashes. Est.1998
cerumo
Postby cerumo » Tue Apr 23, 2019 11:45 am
Only have kick panels
St. Bushy
Postby St. Bushy » Sat May 04, 2019 4:34 pm
Looking for the headlight relay retractor with female plug located behind driver headlight, do you have it by chance?
Rhdhecks
Postby Rhdhecks » Fri May 24, 2019 1:11 am
Still have speedo cable?email me Oneeviljdmef9@sbcglobal.net
x1aO
Postby x1aO » Thu Jul 11, 2019 12:24 am
interested in the fenders if you have it thanks
Emeripino
Postby Emeripino » Mon Jul 22, 2019 7:40 pm
Do you have both wiper arms available?
cerumo
Postby cerumo » Wed Jul 31, 2019 8:00 pm
I do have wiper arms, speedo cable and fenders avaliable.
x1aO
Postby x1aO » Tue Aug 06, 2019 10:03 pm
passenger headlight assembly
cerumo
Postby cerumo » Tue Aug 13, 2019 10:52 am
Text me for pictures
cerumo
Re: Socal Clean Title 1985 Gts Hatch parting out!
Postby cerumo » Fri Aug 30, 2019 7:40 pm
added more parts....
ansay
Postby ansay » Thu Sep 12, 2019 3:20 pm
Do you have rear seat trim cards?
ThunderBolt
Postby ThunderBolt » Mon Sep 23, 2019 6:51 am
I am interested in your engine harness. Is it still available?
PHX
Postby PHX » Sat Sep 28, 2019 7:53 pm
Bump for legit seller
cerumo
Postby cerumo » Fri Oct 04, 2019 7:32 am
Engine harness and all interior pieces are available.
idreamofdrifting
Postby idreamofdrifting » Mon Nov 11, 2019 2:05 pm
+1 Legit seller, and a great guy!
wulfstan
Postby wulfstan » Fri Nov 22, 2019 10:53 am
Email sent
regarding tails
enano1224
Postby enano1224 » Tue Jan 07, 2020 10:09 pm
Still have rear gts seats if so what color?
cerumo
Postby cerumo » Sun Jan 12, 2020 11:14 pm
grey, text me for picture.
Users browsing this forum: Google Adsense [Bot] and 7 guests
