Sold my ongoing project, still left with some parts. Prices are FIRM and already way discounted on BNIB stuff. Look up costs and then realize I not doing this for charity or looking to fit something into someones budget. Parts located in Baldwin Park or Glendale/Burbank area. I am willing to ship some of the smaller stuff that can be easily boxed up if you pay shipping and PP fees.
You can text (8ight 0h f1ve) 5ive 5ive 8ight - 0ne 2wo 0h tw0
AP1 F20c engine and transmission, $4000
-Superb compression across the board <10% on dry motor - great looking head (see pics)
-Spoon oil cap
-Blocked off unnecessary water ports and Air pump. Have air pump delete chip for sale as well (see below)
-Brand new belt, plugs, tstat, gaskets (minus head, never been apart) new TB cable brackets 0 miles.
-OEM sandwich plate delete, replaced with aftermarket sandwich plate with -10an ports
-Including Oil pressure sensor external hose mounting; so sensor isn't mounted directly to the head.
-Oil pan modified for ae86 cross member with 2 bungs welded for oil return/or oil temp (can be blocked off if you choose)
-Valve cover has been reconditioned wrinkle black
-Block and trans pressure washed and clean.
-AP2 header, modded cross member, aem fuel rail is not included in the sale but we can arrive at a deal if interested. OEM fuel rail included.
Science Of Speed Clutch s2000 clutch, ultirlight flywheel w/alignment tool and release bearing $1000
-BNIB
F20c AEM fuel rail BNIB $200
-BNIB
OEM f20 clutch slave BNIB $60
F20 ap2 header $160
-Better flow than ap1, comes with heat shields.
x2 f20 WIX filters 51334 30$
Sparco Corsa seat, red, used $240
IZZe engineering air pump jumper chip, s2000 BNIB - $55
-removed air pump CEL when blocked off
s2000 ECU, removed immobilizer $200
Can be used for ae86 swap with no need for the s2k key.
AE86 f20c single piece drive shaft from Driveline - $300
-with balance tabs
Mishimoto overflow tank MMRT-CA BNIB, fittings-hose incl - $66
AE86 T3 triangle fender braces, new - $180
AE86 Tanabe front swaybar with bushings, New - $255
AE86 T3 Lower control arms, new - $350
RACEREADY AE86 rear end 3rd member, assembled -$2700
- Brand new JDM KAZZ 1.5 LSD
-weir SC/turbo axle and side gear kit and new bearings, ARP wheels studs, Cusco panhard lowering plate welded on, housing refinished
-0 miles- never filled w/fluid comes with new can of Kaaz 80w-90 hypoid break in oil.
Assembled by Jacky K1, ready to bolt, go and never worry about breaking something again.
4x 17x8 +35 GOLD Regamaster MP w/80% RS3 - $2000
Precedo Demon Camber wheels 15x7/7.5 0/-5 4x100/114 perfect cond. - $1050
4x100 AND 4x114.3 bad ass wheels
AE86 F20c modified crossmember tig welded plate reenforced, no joke- $330
- wont twist or be sketchy like a backyard hack job cross member will
2x Walbro 255lph fuel pump(s) - $95 each
-One used on a race car for 500 miles, the other was used to test fit in a fuel sump.
Ae86 Coupe Kouki tail lights L and R - $220
-no cracks no swirls
LA- Racecar part out. F20c & good stuff BNIB!
Re: LA- Racecar part out. F20c & good stuff BNIB!
list updated with sold parts.
Do you still have the Axles available?
call or text me i need one Kouki axle.
925-528-9286
925-528-9286
I want those rear brakes, but I'm currently on a trip, so can you email me?
blaincox7@gmail.com
blaincox7@gmail.com
the drive shaft still available ?
