Sr5 partout/ garage cleanout!
boosted86
Postby boosted86 » Fri Jul 10, 2015 10:28 pm
Hey all, got an sr5 coupe I just tore down, and need to make space in my garage again.
I have about 3 cars worth of varying parts, interior, wiring, plugs, doors, front subframes, clusters, etc. if you're looking for anything specific let me know I'll get back if I have any.
Partial picture post of 3 pairs of doors I have around, all manual crank, some have good mirrors, all good glass and window cranks.
Random probably ebay panhard bar, heater/blower/ control panel set, all interior bits.
The shocks pictured are bnib was told they are mr2s, but numbers pop up as corollas, I'll look into it more. Have ebay coilover sleeves to go with the front and rears if desired.
Also have a front coilover setup with kyb gr2 shocks up front and TRD springs rear and matching gr2 shocks I'm willing to put up, ill get pictures of those this weekend.
Added a few more things!
Front coilover setup using ground control sleeves, 8kg springs, tokico hts short stroke shocks up front
Rx7 brake calipers rebuilt over winter with brackets rotors and new pads(hawk I believe)
Rear trd springs(think color designation blue) with tokico hts shocks.
Kouki coupe tails and garnish, driver has small chip in it I epoxied it last year never had moisture inside casing.
Extra subframes, front spindles, and a set of struts with I believe early corolla/supra springs and brakes.
message me here or call/ text at 618 709 2773 for any info/ questions, thanks!
previadrifter
Re: Sr5 partout/ garage cleanout!
Postby previadrifter » Sat Jul 11, 2015 9:43 pm
Where are you located?
boosted86
Postby boosted86 » Sat Jul 11, 2015 10:24 pm
Midwest il, nearby st louis mo
altezzaae86
Postby altezzaae86 » Mon Jul 13, 2015 8:49 am
Any auto Trans crossmember?
boosted86
Postby boosted86 » Mon Jul 13, 2015 8:51 am
If they are different than manual, then no.
Mr. Angry
Postby Mr. Angry » Tue Jul 14, 2015 9:47 am
Do you have a water pump pulley for a 4ac?
boosted86
Postby boosted86 » Tue Jul 14, 2015 10:15 am
No sorry, only toyota motor I have left is a 3tc
mullinerjames
Postby mullinerjames » Tue Jul 14, 2015 11:19 pm
do you have the left rear quarter panel?
boosted86
Postby boosted86 » Wed Jul 15, 2015 7:24 am
I have one I might be willing to cut off my other car, the frame is bent and I am debating on cutting the rockers out for my new shell..
That's what it looks like, but it's been rolled and pulled pretty far, I think around 35mm?
Let me know if you're interested
kiwi
Postby kiwi » Wed Jul 15, 2015 6:47 pm
Do you have any stock springs?
boosted86
Postby boosted86 » Wed Jul 15, 2015 7:34 pm
Just a front set, I have cut trd in the rears available.
ae86_dreamer
Postby ae86_dreamer » Thu Jul 16, 2015 11:09 pm
how much for the pan bar
boosted86
Postby boosted86 » Fri Jul 17, 2015 6:05 am
40 bucks shipped?
olive86
Postby olive86 » Fri Jul 17, 2015 9:43 am
need the heater core, also any black window cranks? door handle (inside)
boosted86
Postby boosted86 » Fri Jul 17, 2015 10:31 am
I have one, ill check and make sure it's ok and ill post pictures. And ill have to see about cranks
disjaukifa
Postby disjaukifa » Fri Jul 17, 2015 11:12 am
How much for the KYB shocks for the front and rears with the coil overs?
boosted86
Postby boosted86 » Fri Jul 17, 2015 1:33 pm
Sent you a pm
JaySee
Postby JaySee » Sun Jul 19, 2015 6:52 pm
Do you have the spark plug valley cover for a 16v ?
If you do, email me some pics im interested jancarlotorres4@gmail.com
Thanks
hachipirate
Postby hachipirate » Tue Jul 21, 2015 3:31 pm
Bump for boosted. Thanks for the parts!
boosted86
Postby boosted86 » Thu Jul 30, 2015 5:00 am
Bump! Will be adding more to the list soon
ratoy77
Postby ratoy77 » Fri Jul 31, 2015 5:58 pm
i need the a/c stabilizer amplifier that sits behind the glove box. Can you please check for me if u have it? thanks!
Matt_byck
Postby Matt_byck » Sat Aug 15, 2015 1:21 am
I need a front left fender for an 89 gts coupe. as well as the A/C amplifier, and possibly the left drivers side door. also the rear control arms. lower. let me know :D I do happen to live in hawaii so shipping a door might not be the best option.
gladiator
Postby gladiator » Sat Aug 15, 2015 2:21 pm
Do you have a front windshield top molding in good shape. (For example, no dents, no bend or missing parts).
luisfoia
Postby luisfoia » Mon Aug 17, 2015 10:04 am
I need the headlight switch (complete) and could use the gauge cluster.
boosted86
Postby boosted86 » Mon Aug 17, 2015 10:14 am
If you need a door let me know, I have freight available thru work I can get a quote if you want.
I'll check for the windshield molding and take pictures if I have a good one.
I have the headlight switch, and pretty sure I have the cup and knob to go with it. and let me know if you want rhe cluster I have two up for grabs
Matt_byck
Postby Matt_byck » Mon Aug 17, 2015 9:26 pm
boosted86 wrote:If you need a door let me know, I have freight available thru work I can get a quote if you want.
PM'd you
fastginger
Postby fastginger » Tue Aug 18, 2015 11:13 am
I need door panels. Mine are messed up. Drivers side mainly. You haz
Sent from my SM-G900W8 using Tapatalk
F0Bman
Postby F0Bman » Tue Aug 18, 2015 5:00 pm
I am interested in the fuel tank sender unit lid , located in the trunk. Also the alternator bolt and nut for the 4AGE. and any maroon interior pieces you might have.
boosted86
Postby boosted86 » Wed Aug 19, 2015 4:51 am
Ill get door panel pictures tonight.
And I have the fuel sender lid, no go on the alternator bolt, and I have a good majority of maroon interior, let me know what you're wanting.
F0Bman
Postby F0Bman » Wed Aug 19, 2015 11:17 am
I am interested in the maroon clock bezel, maroon rear shock covers for the hatch, rear passenger side plastics for hatch, front GT-S seats in maroon good condition.
Users browsing this forum: No registered users and 10 guests
