Since a few weeks my 4AGE 20V Blacktop hestitates a bit when cold. The first, let's say about 5 minutes, it struggle to climb in rpm like all torque is gone. After that it runs just awesome. Any ideas about a possible cuase?
This is what i've done thus far:
1) New rotor, distributor cap, plugs and cables (only 9000 km old)
2) Checked the timing with a timing light and it's about 8-9 BTDC
3) Measured the resistance of the primary and secondary coil and it's perfect
4) measured the o2 sensor and that's also perfect
5) measured the distributor and it's good also (didn't measure the gap between the rotor and the contacts yet)
6) Installed a new battery while i had the idea the old one was a bit bad
7) Changed from my Ramair filter to a NEW genuine Apexi filter, seems to make it a bit worse
8) Balanced the itb's past year
9) Engine was completey rebuild about 10k km ago with new pistons, bearings, valve grinding, valve adjustment, new oil pump, water pump all new gaskets etc etc
I'm out of clues. Only thing i could think about is either (one of) the injectors, fuelp pump or fuel pressure regulator. Any idea how to test those?
This is how the spark plugs look (after 10k). I took them out after a short ride. I don't think they look too bad, maybe a bit too much carbon, which might be a sign of running a bit lean. On the dyno (about 7k km ago my A/F was just perfect (between 0.85 and 0.9) at full throttle.
