20v swap guys I need your input!!
Posted: Wed Dec 04, 2013 1:54 pm
by alavelle12
Ok for all you guys running 20v swaps, what clutch/flywheel setups are you running and how do you like them? I'm going to be doing some drifting/spirited driving with mine and am trying to figure out the best setup for me.
Thanks,
Alec
Re: 20v swap guys I need your input!!
Posted: Thu Dec 05, 2013 4:11 pm
by MisterJerk
you can get away with the stock clutch/flywheel. Unless you like to clutch drift, or just beat up the clutch when you drive.
Posted: Tue Dec 31, 2013 9:29 am
by teamkunimitsu
yes if your in a budget stock flywheel will do but a lightened flywheel will really wake up the motor response wise.
Posted: Wed Jan 01, 2014 12:58 am
by NZ4age
Had one of these in my old one, great clutch and can take a bit of a beating, nice in the traphic too, don't get too much of a dead leg.
http://japrace.com/products/Exedy-Sport ... E-20v.html , on blacktop 20v flywheel which is lighter than silvertop 20v, lighter flywheel would definitely make it rev better and quick but loose torque
Posted: Wed Jan 01, 2014 7:54 am
by yoshimitsuspeed
NZ4age wrote: lighter flywheel would loose torque
That is completely untrue. A lighter flywheel will free up power across the board. The only place it will sacrifice it in stored inertial energy when launching.
Personally this is the clutch I would go with.
http://matrixgarage.com/products/act-sp ... -kit-212mm If it's mating to a RWD trans you will need this bearing.
http://matrixgarage.com/products/exedy- ... earing-t50The other option would be to put a 200mm flywheel on it and getting a standard AE86 disk and PP in it.
