Blacktop 20v COP issues with OEM ECU?
TheOxyMorin
Postby TheOxyMorin » Mon Oct 07, 2013 4:28 pm
Hi everyone,
I'm converting to COP ignition using either 1ZZ or 1NZ coil packs. I've heard the OEM Blacktop ECU doesn't always work out with this conversion? Can anyone shed some more light from experience with any of these problems? I've seen rev limit at 6,500 with or without load.
Anything would be great, thanks!!!
morgan
Re: Blacktop 20v COP stock ECU issues?
Postby morgan » Mon Oct 07, 2013 5:47 pm
I put the 1zz on my friends BT for him. Backfire out the intakes no matter what i did. Swapped my D17 honda coils from my 20v, wired it up quick and his car started. Personally i always have luck with the D17 coils, never the 1zz or 1nz
My turd of an 86
20v swapped 86 write-up
TheOxyMorin
Postby TheOxyMorin » Mon Oct 07, 2013 6:01 pm
morgan wrote:I put the 1zz on my friends BT for him. Backfire out the intakes no matter what i did. Swapped my D17 honda coils from my 20v, wired it up quick and his car started. Personally i always have luck with the D17 coils, never the 1zz or 1nz
Thanks Morgan, I ordered a Tweak'd harness... shouldn't be a difficult job to change out connectors and a little solder right? How's his engine run all the way to redline?
morgan
Re: Blacktop 20v COP issues with OEM ECU
Postby morgan » Mon Oct 07, 2013 6:20 pm
Better with colder plugs. Pulls nice
My turd of an 86
MisterJerk
Postby MisterJerk » Tue Oct 08, 2013 10:01 am
morgan wrote:Better with colder plugs. Pulls nice
Which plugs? BCPR6? or 7? Im not sure what is stock in the 20v.
I know its a BCPR5ES11 for 16v low comp(zenki, blue top, whatthefuckever)
morgan
Re: Blacktop 20v COP issues with OEM ECU?
Postby morgan » Tue Oct 08, 2013 10:57 am
i dont recall off hand, ill check later when im home. hope i remember...
My turd of an 86
TheOxyMorin
Postby TheOxyMorin » Tue Oct 08, 2013 3:26 pm
That's good to hear, I think I am going to try OEM 1ZZ coils packs first as a test. Then if all else fails I'll switch to the D17 packs. Thanks again Morgan
alavelle12
Postby alavelle12 » Tue Oct 08, 2013 3:51 pm
BCPR7ES # 6282 are the 1 step colder plugs i believe
morgan
Postby morgan » Tue Oct 08, 2013 3:54 pm
Just got in, you are correct on those plugs^
My turd of an 86
TheOxyMorin
Postby TheOxyMorin » Tue Oct 08, 2013 4:09 pm
alavelle12 wrote:BCPR7ES # 6282 are the 1 step colder plugs i believe
Good looking out Alavelle, thanks for the post
speedmaster
Postby speedmaster » Thu Oct 10, 2013 6:25 pm
COP with stock ecu works just fine?
TheOxyMorin
Postby TheOxyMorin » Thu Oct 10, 2013 6:36 pm
speedmaster wrote:COP with stock ecu works just fine?
Sometimes, as far as I can tell so far it's a game of luck.
onnaj
Postby onnaj » Sat Oct 12, 2013 5:45 am
Why do you want COP with a stock ECU anyway, besides that it might look sexy? The stock ignition is pretty decent.
TheOxyMorin
Postby TheOxyMorin » Sat Oct 12, 2013 5:55 am
onnaj wrote:Why do you want COP with a stock ECU anyway, besides that it might look sexy? The stock ignition is pretty decent.
Running a COP setup is cleaner, involves less moving parts, and the cam gear cover can be fitted as original for maximum protection of the timing belt. Running COP is nearly the same price as a distributor relocation kit. I am undecided if switching to a standalone at a later date until I am more financially able.
morgan
Postby morgan » Sat Oct 12, 2013 8:00 am
Plus its going into an ae86 right? Space is an issue with distributor then
My turd of an 86
Users browsing this forum: No registered users and 14 guests
