how to install AFPR on 20V (BT)
Posted: Wed Jul 10, 2013 4:58 am
by onnaj
Hello,
I want to install an adjustable fuel pressure regulator on the 4AGE 20V Blacktop, mainly so i can check the actual fuel pressure, but i like to be able to adjust it.
I don't know how to exactly install it. I think the stock FPR falls in the hole of the fuel rail on one side and has a special oring. On the other side it has the fuel return hose attached and ofcourse the vacuum hose.
Someone has good tips how to best install it?
Thanks
Re: how to install AFPR on 20V (BT)
Posted: Thu Jul 11, 2013 5:14 pm
by ga_goosh
it all depends on what fpr you choose. here is one for a b&m fpr from dr occa
http://www.86garage.com/forums/viewtopic.php?f=47&t=1664
Posted: Fri Jul 12, 2013 3:12 am
by onnaj
I've ended up buying an adapter for the fuel rail.
The one one the picture is for the Honda i believe, the one from Toyota has a bigger tube (don't know the right word in english for this) where you put it in the fuel rail.
Maybe i'm going to fit it this afternoon, so i'll let you guys know if it'll work.
Thanks
Posted: Mon Jul 15, 2013 12:10 pm
by onnaj
FYI -> the adapter works. Had to adjust it a little bit to make more room for the screws.
Unfortunately is the AFPR i bought not working :( So kept it stock.
Posted: Tue Jul 16, 2013 8:09 am
by choi0706
part number on that adapter ?
Posted: Tue Jul 16, 2013 9:14 am
by onnaj
It's called the D1 Spec Fuel Pressure Regulator Adapter for Toyota. As mentioned you have to adapt it a little bit to make the screws fit the holes.
It costs about 13 dollar i think, here is the webaddress: http://www.fullcartuning.com/45359/D1-S ... or-Adapter
Posted: Tue Jul 16, 2013 11:43 am
by onnaj
Or buy this one: http://www.ebay.nl/itm/Toyota-Corolla-M ... 1e7b92ca59
Think that one doesn't need to be adapted ;)
Posted: Tue Jul 16, 2013 12:14 pm
by yoshimitsuspeed
Posted: Thu Jul 18, 2013 9:03 pm
by choi0706
geez shipping is really killer.. any way you can drop it in a flat rate box or envelope?
this is bolt on, correct? no modifying..
Posted: Fri Jul 19, 2013 10:50 am
by yoshimitsuspeed
choi0706 wrote:geez shipping is really killer.. any way you can drop it in a flat rate box or envelope?
I don't have them in stock so either I ship them straight from my distributor or have to add the shipping cost getting them to me and then shipping them out to customers.
Unfortunately my distributor doesn't have a lot of shipping options and I could probably ship you 10 for the same cost as one.
That said I am still dialing in my shipping calculator on my website. What was the quote and where are you located?
choi0706 wrote:this is bolt on, correct? no modifying..
I just recently found these and haven't sold one or tried one yet but yes they should be bolt on with no modification.
Posted: Mon Jul 22, 2013 2:22 pm
by choi0706
16.41 to business address in Sealy , TX 77474
Posted: Mon Jul 22, 2013 7:53 pm
by yoshimitsuspeed
choi0706 wrote:16.41 to business address in Sealy , TX 77474
Oh my, lol. Thanks for the heads up.
I will try to play with the shipping settings tomorrow.
If you want you can send $32 via paypal to yoshimitsuspeed at matrixgarage.com with the part number and shipping addy.
Otherwise I'll post back up here after playing with my shipping settings.
Posted: Mon Jul 22, 2013 10:12 pm
by choi0706
paypal sent
Posted: Tue Jul 23, 2013 12:54 pm
by yoshimitsuspeed
choi0706 wrote:paypal sent
Order processed.
Posted: Thu Aug 08, 2013 5:05 pm
by choi0706
was it shipped out?
Posted: Fri Aug 09, 2013 12:16 pm
by yoshimitsuspeed
choi0706 wrote:was it shipped out?
It shows delivered on the 26th. I'll PM you the tracking no and make sure I got the right addy and everything.
