Alright guys, so I am trying to convert my blacktop 20v from a hydraulic to a spring tensioned timing belt. Now I understand that this requires a 16v oil pump and spring style timing tensioner, as well as a silvertop timing belt. My issues come in to what parts exactly would be best to use with the 20v, like a hicomp oil pump or other? I also need to know what you guys use as the pin for the spring tensioner, as I am converting my sr5 so i can't just pull one out of my motor. Lastly, do i need to get a 16v timing crank sprocket? or should the original 20v one work fine?
All p/n's would be greatly appreciated, along with links to where i might purchase the items.
Thank you,
Alec
20v to 16v oil pump/timing belt conversion
- alavelle12
Re: 20v to 16v oil pump/timing belt conversion
High comp pump, 16v crank sprocket, any 16v tensioner and spring. The tensioner comes with the pin
My turd of an 86
20v swapped 86 write-up
My turd of an 86
- alavelle12
Where would you actually get these from then? The dealership, or do you guys know of a better or cheaper place?
Contact TOR Parts on here, tell them Morgan sent you
My turd of an 86
My turd of an 86
- alavelle12
Thank you very much sir.
