Troubleshoot: 16V smallport not starting
Posted: Tue Mar 26, 2013 12:08 am
by APO6
problem resolved.
Re: Troubleshoot: 16V smallport not starting
Posted: Tue Mar 26, 2013 7:39 am
by yoshimitsuspeed
Make sure there isn't any moisture in the spark plug wells. It's unlikely it would kill all four cyls but not impossible. To eliminate the dizzy you could see if there is spark coming directly off the coil wire.
Are you bolting the coils on? They ground through their mount to the chassis. If you leave it hanging or don't have a clean connection where it mounts then you won't get spark.
Posted: Tue Mar 26, 2013 7:40 am
by totta crolla
Check inside the distributor cap for damp.
Diagnostic test ?
Posted: Thu Mar 28, 2013 4:25 pm
by APO6
no spark coming from the coil wire and coil is mounted/grounded onto chassis. distributor cap/rotor look fine.
