AE101 4agze vacuum lines help
Posted: Wed Mar 06, 2013 1:37 pm
by greyae92
I have a 4agze, it didn't come with any vacuum lines, no hard lines, no soft lines. I don't know where anything plugs into. If someone could shoot me some pics and label what goes where I'd really appreciate it. I can't seem to find any reliable pics of things and a factory diagram gives me little help since I don't have most of the lines they show. Thanks!!! You can post of email me greyae92@yahoo.com
Re: AE101 4agze vacuum lines help
Posted: Wed Mar 06, 2013 6:35 pm
by greyae92
If I could find out exactly where the map sensor connects to and where the FPR vacuum hooks to that would be enough for me to get the car running
Posted: Fri Mar 08, 2013 8:52 am
by jdm86gtz
On the intake manifold next to the cold start injector there is a nipple in the manifold Tee this to the fuel pressure regulator and the bottom nipple on the air bypass valve. On the back of the manifold there is a screw in vacuum tree and connect the map sensor to that.
Posted: Fri Mar 08, 2013 3:13 pm
by greyae92
The only other connection I see on the intake manifold itself is the inlet air temp sensor
Posted: Sun Mar 10, 2013 6:02 pm
by jdm86gtz
This nipple with the blue hose on it is what you Tee the FPR and ABV to and boost gauge if you have one:
This is for the MAP sensor at the back of the manifold, air temp is on the side:
Posted: Sun Mar 10, 2013 6:34 pm
by greyae92
Thank you!! That explains a lot, I don't have that vacuum tree, I just thought it was a bolt hole for mounting something and it's almost non visible with the wire harness over it. Next question, can I use a vacuum tree off of a 4age in place of that or do I need a 4agze one?
Posted: Mon Mar 11, 2013 6:16 am
by jdm86gtz
Yeah 4AGE one will work, just block the other 2 nipples on it or take your boost gauge supply from one of them.
Posted: Mon Mar 11, 2013 6:36 am
by greyae92
Exactly what I needed to hear! Thanks for the help
