"I was told the car was a swap, and not original engine.."
1) Temperature Gauge, Fuel Gauge, Oil Gauge doesn't not work. (Tachometer and Speedometer works)
I noticed that when I turn on the key to "ON" position, the temp gauge needle moves a little bit as showed in the video.
https://streamable.com/qhqoo1 <--- Video
I have checked the Upper water neck coolant sensor and the oil sender and they are not loose.
I switched gauges and nothing is working.
- I looked at Firewall / Valve colver ground and it's fine
- I looked at Driver side frame rail and engine block ground and it's all tight too
- I couldn't find the tranmission ground? Does anyone have a photo?
There are only 3 grounds correct?
2) There's a pinging noise when idling, and not sure how to fix it or how to diagnose..
3) The last one is that, when reving up, and as it comes down, you can hear a knocking rattling noise.. Not sure what it is. Please help guys! Thank you so much
Video for 2/3: https://streamable.com/0uc82z
