engine sealing questions
tlea
Postby tlea » Wed Aug 22, 2018 6:41 am
Hi. Before we fit the 20V into the car I am re sealing the engine. I ordered new seals and gaskets from Battle garage but there are a few they didn't list.
Oil pan= Is this just silicone?
lower timing cover (oil pump?) silicone?
injector seals- they had a kit that has 4 large/4 small o rings that go around the injector but when I removed them there is also what looks like and o ring where the tip contacts the manifold
Thanks
jdm86gtz
Re: engine sealing questions
Postby jdm86gtz » Thu Aug 23, 2018 4:29 am
Oil pan is FIPG sealer.
Oil pump has a gasket.
Each injector has 4 o-rings, 2 fuel, 1 to seal against the manifold and the other is on top between the injector and retaining plates.
