4AGE Turbo Setups and numbers
XanManAE86
Postby XanManAE86 » Sun Mar 26, 2017 6:37 pm
I'm probably alone in thinking this, but I'd like to revive this thread from the old forum. I want to see what people are running setupwise and what the results are. I've yet to dyno mine but it's somewhere close to 200 hp I'm assuming.
AW11 GZE Block
Arias 82mm 8.6:1 Pistons
Stock gze rods
Stock gze crank
Polished big port head
TRD 0.8mm HG
Stock gze cams
Port matched tvis deleted IM
2AR Injectors ~420cc
2GR fuel pump
2AZ Coil on plug
2ZZ iridium spark plugs
Custom log manifold
Borg warner S251SX turbo
AGP Turbo 0.48 turbine housing
Tial 38mm MVS wastegate
Megasquirt 2 V3.0 ECM
Currently spools between 3500-4000 to 11 psi and hits around 13.5 psi at 7500, boost creep probably due to poor wastegate placement.
Rogue-AE95
Re: 4AGE Turbo Setups and numbers
Postby Rogue-AE95 » Sun Mar 26, 2017 7:18 pm
You are not alone, I would also like to see the builds with numbers. I'm planning a 7A-GTE in the future for my wagon. I was thinking about the GT2860RS.
'88 Corolla All-Trac
XanManAE86
Postby XanManAE86 » Sun Mar 26, 2017 7:46 pm
That's the turbo I would've bought if I had more money. But the BW new was $750ish. It's close to the old 50mm T3 specs but with new technology.
GZE_RA21
Postby GZE_RA21 » Tue Apr 04, 2017 10:35 pm
Would like to see people's numbers on this also, curious to do my own turbo setup in the near future on my smallport 4agze.
