OST-039: The end of the beginning....
Postby oldeskewltoy » Thu Jun 09, 2016 3:16 pm
Next few pics are just the difference from dirty, untested, to cleaned and fully pressure tested - rebuild ready.
Hmmm, the sharp of eye might say, "hold on there... some of those exhaust valves seem to be thin of margin"......
and you'd be correct....... 4 exhaust valve were marginal on the margin
although .8mm will likely still have "enough" margin after being cut, once you add in a stronger spring, and likely hotter temps, I want exhaust valves with a bit more than the minimum, so I dug up some exhaust valves to replace those I've removed.
More to come....... :D
Re: OST-039: The end of the beginning....
Postby oldeskewltoy » Fri Jun 10, 2016 10:25 am
Well this head is receiving a complete deburring, all machined edges get a general deburring.
and a bit closer of the area between the buckets.... this work is all designed to shed excess oil, and to remove casting flash.
and a 2 panel showing the deburring of #1 exhaust journal
more to come....... :mrgreen:
Rogue-AE95
Postby Rogue-AE95 » Fri Jun 10, 2016 6:26 pm
I always love seeing your work. It's the attention to detail :idea:
I practiced that between-buckets deburring on my "junk" bigport head. Seems like a good idea to stick a "junk" bucket (or a maybe socket) in place to ensure that the Dremel bit doesn't jump over and leave a mark there.
I also practiced some block deburring. There seems to be quite a bit of casting flash inside the big oil drain on the exhaust side. Or there was on the one I was working on.
Postby oldeskewltoy » Mon Jun 13, 2016 10:28 am
Rogue-AE95 wrote:I always love seeing your work. It's the attention to detail :idea:
The big oil drain... isn't. The kidney shaped twin openings on the exhaust side between cyls 2 and 3 is not an oil drain, it is the breather bypass. The 4AG bigport head has 2 oil drains - both on the exhaust side, one just after cyl #1, and one at the back of the head near #4.
from another form wrote:Thanks for the info as always! One thing I was wondering about that HKS oiling mod blocking the main galley going to the block. How big is that restrictor orifice? and does it really restrict the flow as the restrictions in the head are much smaller than the hole in the block feeding it.
seems like it is a significant restriction..... another solution would be to add passages for the head to drain the oil back into the oil pan
Work begins on #1.... the seat diameters are enlarge by about 3/4 mm... opening the valve to seat ratio to 85%, blending the bowl to the seat... as best as can be without over enlargening the seat. Since this head has no client yet, (contact me if interested...) this head is being built similarly to OST-032, built to boost air flow (volume AND velocity).
And as always... working the short radius.....
and a bit closer to show more detail on the short radius work.
more to come....... :D
Postby oldeskewltoy » Tue Jun 14, 2016 8:44 am
and the first exhaust port is complete...
​more to come..... :D
Postby oldeskewltoy » Thu Jun 16, 2016 9:16 am
bowl and seat clean up go a long way to improved flow.... ;)
more to come.... :D
Postby oldeskewltoy » Thu Jun 16, 2016 1:18 pm
from another forum wrote:Dude,
It will be interesting to see the before and after flow-rate comparisons.
Yes it would.... and so I've re-calibrated the bench....
then I fitted test valves and test springs... and put the head on the bench and got baseline numbers for intake, and exhaust
and the results....
exhaust:
.050" - 29.8 cfm
.100" - 62.4
.150" - 95.8
.200" - 112.2
.250" - 118.3
.300" - 121.3
.350" - 121.8
Intake:
.050" - 39.4
.100" - 79.8
.150" - 118.8
.200" - 150.2
.250" - 171.9
.300" - 177.8
.350" - 180.2
more to come........ :D
Postby oldeskewltoy » Mon Jun 20, 2016 9:27 am
and a bit more detail.....
flow results to follow........
Postby oldeskewltoy » Tue Jun 21, 2016 12:04 pm
oldeskewltoy wrote:
and the results.... (before)
exhaust:
.050" - 29.8 cfm
.100" - 62.4
.150" - 95.8
.200" - 112.2
.250" - 118.3
.300" - 121.3
.350" - 121.8
Intake:
.050" - 39.4
.100" - 79.8
.150" - 118.8
.200" - 150.2
.250" - 171.9
.300" - 177.8
.350" - 180.2
and now with porting, same valves, old valve job (further improvement likely with fresh 3 angle)
Exhaust:
.050" - 30.4cfm
.100" - 64.4
.150" - 96.5
.200" - 114.3
.250" - 125.5
.300" - 129.3
.350" - 132.0
Intake:
.050" - 39.4cfm
.100" - 80.0
.150" - 122.2
.200" - 156.7
.250" - 182.2
.300" - 197.3
.350" - 204.0
.300" = 7.62mm, or just a tiny bit more lift then early stock cams(7.5mm). .350" = 8.89", or nearly 9mm.
So.... flowing through the stock ports I gain 10cfm@ .350" lift on the exhaust side, and I gained nearly 24 cfm on the intake side.
:D
Postby oldeskewltoy » Wed Sep 28, 2016 2:18 pm
been a while but OST-039 now has an owner... chamber volumes are equalized, depth of cut will determine final chamber volumes
client will be running a 262-232 cam with 8.3mm of lift
Postby oldeskewltoy » Fri Nov 11, 2016 11:48 am
Some specifics were made final, and so the head was machined .004". Cams are in, and clearances are now set, its time to ship this off to its new owner
riddleyo
Postby riddleyo » Tue Dec 20, 2016 1:56 pm
Looks fantastic and thank you for the port numbers!
Did the 3 angle valve job change the flow numbers, specifically at low lifts?
Postby oldeskewltoy » Wed Dec 21, 2016 7:30 am
riddleyo wrote:Did the 3 angle valve job change the flow numbers, specifically at low lifts?
it wasn't put back on the bench, so I can't say for sure.....
Ultimx
Postby Ultimx » Sun Dec 25, 2016 10:49 pm
Thank u for sharing!!!
