v33sonata wrote:What oil weight is used in this motor? Also I am using the stock water pump does anyone know of a lower radaitor hose that works well? and lastly does anyone have vacuum diagrams for the BT?
Thanks
I've personally always ran Honda synthetic blend 10w30 with Toyota "xxxF1" filter. Most people run thicker though. Are you using this engine in a RWD corolla? If so, you use the 16v RWD thermostat housing.
On the BT 20v I'm building right now:
-RWD 16v alternator and alternator bracket
-RWD 16v waterpump w/ 16v pulley
-RWD 16v T3 crank pulley
-RWD 16v thermostat housing w/ AE86 thermostat and AE86 outlet neck on thermostat housing
-The thermostat I have drilled four 1/8" holes in for cold start bypass
-JSP style mod to the 20v cylinder head. Coolant ports cut out and blocked off
-TRD 16v headgasket
-AE92 16v oil pump
-AE86 16v timing belt tensioner
-AE101 timing belt
I've converted the water system to 16v AE86 and the timing belt to AE101 style as the AE111 tensioner usually takes a dump and bends valves. People complain about doing 16v coolant flow direction on a 20v, I've been running it on several different engines for years, daily driven and tracked, never had a problem. All these parts I've listed can be bought right here in the USA from aftermarket or direct from any Toyota dealer. Tally up the cost of a new timing belt, tensioner, oil pump, and water pump for the 20v and this is about 1/4 the price.
I have a YouTube video devoted to the BT 20v vacuum routing. Search "DIY BT 20v vacuum routing". It will be the video by 'HASportAE86'.
