Future Build Components
Rogue-AE95
Re: Future Build Components
Postby Rogue-AE95 » Wed May 25, 2016 3:59 pm
Those do look like good quality. Clevite is a good brand as far as I know (and made in the USA, surprising).
I also have a set of non-OEM, "OEM-spec" smallport pistons. Their quality looks decent, enough that I planned to send them out to be coated before I changed my mind to doing a 7A-GTE.
'88 Corolla All-Trac
Alex170984
Postby Alex170984 » Thu May 26, 2016 1:33 am
Can anyone verify the CC of those pistons please?
Cheers
Does it change if they are oversize 0.040?
Postby oldeskewltoy » Thu May 26, 2016 7:52 am
Alex170984 wrote:Can anyone verify the CC of those pistons please?
Cheers
JE piston measured a std bore Toyota high comp piston and told me it was +0.25cc, I ASSUME the aftermarket are similar. I did not measure them. A high quality aftermarket producer of stock type pistons SHOULD adjust the crown LOWER as bore increases... but I seriously doubt any of these pistons were adjusted for bore
Alex170984
Postby Alex170984 » Thu May 26, 2016 8:12 am
That's odd because another thread on here shows the piston dome volumes in a table and that comes out as 2.1cc - i'm guessing it's not right?
Postby oldeskewltoy » Thu May 26, 2016 11:23 am
oldeskewltoy wrote:JE piston measured a std bore Toyota high comp piston and told me it was +0.25cc
TVIS 9.4:1 pistons came out to -3.8cc
Alex170984
Postby Alex170984 » Fri May 27, 2016 6:17 am
Sorry, I'm asking for the standard OEM 10.3 piston CC not the 9.4:1
Postby oldeskewltoy » Fri May 27, 2016 7:16 am
Alex170984 wrote:Sorry, I'm asking for the standard OEM 10.3 piston CC not the 9.4:1
oldeskewltoy wrote:JE piston measured a std bore Toyota high comp piston and told me it was +0.25cc,
and
Alex170984
Postby Alex170984 » Sat Jun 04, 2016 1:30 pm
I've found some now for £100 delivered including import duty.
Who needs to spend $750...
Alex170984
Postby Alex170984 » Wed Jun 08, 2016 12:45 am
I've found a smallport head and I am looking to buy it.
What differences i.e. components will I need if I swap it over?
Fuel rail?
Water pump?
Cooling pipes?
Anything else?
Cheers
Postby totta crolla » Wed Jun 08, 2016 3:06 am
Going into an MR2 AW11 ?
Alex170984
Postby Alex170984 » Wed Jun 08, 2016 4:17 am
Yes mate.
I've found a fuel rail in the states, unless you have one?
Postby totta crolla » Wed Jun 08, 2016 11:26 am
Alex170984 wrote:Yes mate.
I have 2 or 3 but they are buried in my garage somewhere ?
Alex170984
Postby Alex170984 » Thu Jun 09, 2016 2:39 am
Save me importing...some chaps on AE86org may have one, so hold fire on rummaging.
Alex170984
Postby Alex170984 » Fri Jun 17, 2016 8:49 am
I'm now going to install a small port cylinder head to mix things up even more.
Will obviously use a small port fuel rail and even trying to get a hold of an inlet manifold.
Users browsing this forum: Davegt27, Google Adsense [Bot] and 10 guests
