2nd Gen 4AGE Coolant Manifold
Posted: Tue Apr 05, 2016 9:16 pm
by jondee86
Hey familyman... your post got deleted by mistake due to the generally
fcuked up state of the boards at the moment. Try posting a response to this
thread if you want to ask the question again.
Re: 2nd Gen 4AGE Coolant Manifold
Posted: Wed Apr 06, 2016 3:01 pm
by familyman
Hey guys, I'm a Toyota and AE86 noob. I'm installing a 2nd gen 4AGE in my 85' coupe. I've modified the coolant "manifold" to move the vacuum bung off the block side and changed the outlet for the heater core. Does this look correct?
Thanks in advance!
Posted: Thu Apr 07, 2016 5:40 am
by morgan
the RWD setup has the upper waterneck and the water pump backing plate connected via a "bypass tube". how do you have that bypassed so there circulation while the thermostat is closed? maybe the dashpot is hiding the connection, I see a tube from the upper neck(which isn't the rwd one)
Posted: Fri Apr 08, 2016 6:44 pm
by familyman
morgan wrote:the RWD setup has the upper waterneck and the water pump backing plate connected via a "bypass tube". how do you have that bypassed so there circulation while the thermostat is closed? maybe the dashpot is hiding the connection, I see a tube from the upper neck(which isn't the rwd one)
Yeah, it's connected back there with a silicone hose...
Otherwise looks good, yeah?
Posted: Fri Apr 08, 2016 7:05 pm
by familyman
Better picture of the whole setup.
