16v not feeling too great at low speeds.
ericteti
Postby ericteti » Mon Feb 29, 2016 9:21 pm
Hey guys,
My 16v has been feeling a little weird at low speeds. If I'm in 1-3 gear and remove my foot from the throttle, the engine starts to rubble and shake. This is even happening in 3rd if I'm anywhere below 2800rpm. Giving it a little gas helps a bit, but it isn't until I'm giving it a significant amount that it goes away. Right now, to make a slower turn in 2nd or 3rd, I have to clutch in to avoid the bogging.
4th gear, I have no issues at all with taking my foot off of the accelerator. When I do, things still feel very very smooth.
Any ideas? This has made any low speed driving, such as through my neighborhood, a huge pain.
Thanks!
Re: 16v not feeling too great at low speeds.
Postby oldeskewltoy » Tue Mar 01, 2016 7:51 am
might there be something wrong in the transmission? I know it isn't the engine, but when you say it is in gears 1-3, but once in 4th all is fine. When the trans is in 4th gear the power goes straight through the trans where in 1-3 it goes into other shafts, gears.
ericteti
Postby ericteti » Wed Mar 02, 2016 1:25 pm
oldeskewltoy wrote:might there be something wrong in the transmission? I know it isn't the engine, but when you say it is in gears 1-3, but once in 4th all is fine. When the trans is in 4th gear the power goes straight through the trans where in 1-3 it goes into other shafts, gears.
Hmm I didn't think about that. My transmission shifts fine and doesn't seem to give me problems (unless this is a transmission issue). Having my foot off of the throttle in 5th gear is fine too.
sirdeuce
Postby sirdeuce » Wed Mar 02, 2016 5:19 pm
If it's the trans you'd more than likely hear a new noise or feel something odd. How does the engine do when revved in neutral?
One shot, one kill.
allencr
Postby allencr » Wed Mar 02, 2016 11:08 pm
What's the compression?
Does it miss or surge or feel funny when redlining 2nd & 3rd?
Is the timing adjusted for a smooth fast idle, and octane so it'll only ping/detonate if abused, like trying to accelerate in 3'rd at 2000rpm?
Postby totta crolla » Fri Mar 04, 2016 2:32 am
Diagnostic check ? If it is not the transmission then it could be a fueling issue and possibly also related to the TPS (fuel cut, or lack of, on the idle switch)
Users browsing this forum: allencr and 2 guests
