Hachiphil wrote:Hello, I recently bought a clean 1987 Corolla GTS with a blown motor, Im having the motor rebuilt with Brian Crower rods, CP piston, HKS valve springs, ACL rod bearings, ARP heap studs, HKS head gasket and Kelford cams. Im looking to find out more information about Individual throttle bodies. What do I need to do? Is there a step by step write up?
There are write ups here and other places. A google search should find you a lot of info as well as searching this board.
I would like to address a couple things. I'll start with the ITBs since that's the topic. It sounds like your build is pretty mild. If you are staying under 8500 RPM and a 272ish cam you will not see gains from the ITBs that would justify the expense. It would more or less be for appearance and or sound. If you are okay with that then go for it. As Ratranger said it's not practical to try to get them running on the stock ECU.
Now for the rest of the build.
Which CP pistons? I believe my new design to be better than anything else on the shelf. If you told me more about your build I might be able to suggest something. Unless you are at a level where a custom piston would be better.
I wouldn't use the HKS springs. They don't have specs on them so the best we are left with is testing that people in the community have done and those results don't make them look great.
The spring can depend on the cam but if we are looking at springs in a similar ballpark to the HKS my recommendation are the TED springs.
http://www.matrixgarage.com/products/te ... ve-springsAnother great option are the Toda springs.
http://www.matrixgarage.com/products/to ... ve-springsHKS headgaskets are only offered in 1.6mm and 2mm anymore. The only reason anyone would ever want to run one is if for some reason they shaved 1mm+ too much off their block.
Cometic and Toda offer great head gaskets in a variety of thicknesses. I can get both.
Which cams are you looking at? Have you gotten them already?
