blacktop FSM incorrect?
Does anyone remember the correct timing setup for blacktop? I remember there was a thread on here on the old site.. we lost so many good threads..
Re: blacktop FSM incorrect?
Exhaust cam pulley knock pin placement
- HASport AE86
You are to align the dowel pin on the exhaust cam WITH the pulley spoke that HAS A "5" and a "dot" on it. Following the FSM will in fact put your exhaust cam advanced 11 teeth and the distributor timing will be way off. At TDC #1, the dowel pin on the exhaust cam should be in about the 5 o'clock location and the slit for the distributor on the opposite side of the cam should be perfectly vertical at 12 o'clock.
You can find that thread that HaSport and I did collectively...without knowing it.
viewtopic.php?f=4&t=1353
My turd of an 86
20v swapped 86 write-up
My turd of an 86
