tvis problem maybe
supo4
tvis problem maybe
Postby supo4 » Thu Jul 02, 2015 4:51 pm
hey guy to make a long story short I have just pulled the 16v big port 3 rib out of a mr2 and put it in one of my ae86s so other than some brackets and water pump pulley head ache a strait drop in. I've been driving the carp out of the car and I was going down the road turning 2900 rpm and my engine light came then I had to turn and I shifted and it was gone as soon as the rpms changed. now the next day I was driving and I was tuning 3100 rpm and the light came on so sped up to 3800 rpm and it went away. I've been driving still and I am noticing as long as it is the range of the tvis opening ,if my understanding is correct 2700-3200, and held at a constant speed the light comes on any ideas?
1966 mustang (my lover)
2006 f150 (my regular)
1986 gts Corolla (my affair)
bigbacon
Re: tvis problem maybe
Postby bigbacon » Thu Jul 02, 2015 6:28 pm
Make sure the TPS is adjusted. If it isn't adjusted correctly this can happen. Mine 87 MR2 used to do this all the time when it hit a certain RPM, I think it was high 3s, the TPS was the issue, adjusted it and it went away.
Pretty sure the TVIS opens at like 4100 rmps or around there.
