build 7agze sc14 what strater ??
crazyae86
Postby crazyae86 » Thu Apr 02, 2015 4:21 am
hey to all i am start on build my friend engine for rolla i will make 7agze
7afe block with sc 14 and head 4age big port i think its a little bit storng so i need to know what starter i will need ??
oem ae86 i think is waek with this engine its much power
i heard from ae92 fit it on corolla trans
what about 1g what is this starter ??
any ideas ??
Evo_lucian
Re: build 7agze sc14 what strater ??
Postby Evo_lucian » Thu Apr 02, 2015 10:46 am
stock starter is fine.
crazyae86
Postby crazyae86 » Thu Apr 02, 2015 2:35 pm
Evo_lucian wrote:stock starter is fine.
hi you mean 7afe ??
i will go about 250-300ps is this starter good enougth ??
i want to go with w58 trans ( t50 is weak as we know ) i want to use 225-230mm flywheel from 4agze
i have ( all engine ) from 4agze ae92 can i use it ??
Postby yoshimitsuspeed » Thu Apr 02, 2015 2:55 pm
hi you mean 7afe ??
The starter couldn't care less how much power the motor makes.
Compression is the only thing that will effect the starter so a 180 WHP high comp build would be more load on the starter than a 500 hp turbo low comp build.
Use whatever starter fits the bellhousing you are using.
Evo_lucian
Postby Evo_lucian » Fri Apr 03, 2015 7:17 am
yoshimitsuspeed wrote:The starter couldn't care less how much power the motor makes.
ae82hybrid
Postby ae82hybrid » Wed Apr 08, 2015 8:57 am
hi you mean 7afe ??
Agreed.
Users browsing this forum: jdm86gtz and 6 guests
