4e flywheel
Posted: Wed Mar 18, 2015 4:56 am
by speedmaster
Will the 4e 6bolt flywheel fit the 7a crank?
Thanks
Re: 4e flywheel
Posted: Wed Mar 18, 2015 9:52 am
by yellowsnow4free
speedmaster wrote:Will the 4e 6bolt flywheel fit the 7a crank?
Thanks
If you're asking if a 4AFE flywheel will fit a 7AFE crank, then yes, it should.
I believe you need to get a matching pressure plate to your flywheel size though.
Re: 4e flywheel
Posted: Wed Mar 18, 2015 9:56 am
by speedmaster
I saw the 4efte flywheel has 6bolts and 212mm. The clutch kit can be used in 4age. So was wondering if the OEM flywheel can be swapped to 7a crank
Re: 4e flywheel
Posted: Thu Mar 19, 2015 4:13 am
by Evo_lucian
IIRC when we tried a 4efte flywheel on a 7a some years ago, it was a bit thinner so the starter motor couldn't make contact.
Re: 4e flywheel
Posted: Tue May 19, 2015 6:45 pm
by speedmaster
Evo_lucian wrote:IIRC when we tried a 4efte flywheel on a 7a some years ago, it was a bit thinner so the starter motor couldn't make contact.
Thank you
Re: 4e flywheel
Posted: Wed May 20, 2015 1:25 pm
by jamspi
4efte and 7afe are different bolt pattern it will not fit
Re: 4e flywheel
Posted: Fri May 22, 2015 3:26 am
by speedmaster
jamspi wrote:4efte and 7afe are different bolt pattern it will not fit
They look almost fit. Thanks bro
