Will the 4e 6bolt flywheel fit the 7a crank?
Thanks
4e flywheel
- speedmaster
4e flywheel
Visit my FB fan page at https://www.facebook.com/speedmasteracing
Re: 4e flywheel
speedmaster wrote:Will the 4e 6bolt flywheel fit the 7a crank?
Thanks
If you're asking if a 4AFE flywheel will fit a 7AFE crank, then yes, it should.
I believe you need to get a matching pressure plate to your flywheel size though.
- speedmaster
Re: 4e flywheel
I saw the 4efte flywheel has 6bolts and 212mm. The clutch kit can be used in 4age. So was wondering if the OEM flywheel can be swapped to 7a crank
Re: 4e flywheel
IIRC when we tried a 4efte flywheel on a 7a some years ago, it was a bit thinner so the starter motor couldn't make contact.
- speedmaster
Re: 4e flywheel
Evo_lucian wrote:IIRC when we tried a 4efte flywheel on a 7a some years ago, it was a bit thinner so the starter motor couldn't make contact.
Thank you
Re: 4e flywheel
4efte and 7afe are different bolt pattern it will not fit
- speedmaster
Re: 4e flywheel
jamspi wrote:4efte and 7afe are different bolt pattern it will not fit
They look almost fit. Thanks bro
