4A 7A Clutch Question
speedmaster
Postby speedmaster » Wed Feb 25, 2015 3:25 pm
I have a few question on clutch system.
1. Does a 7A 200mm flywheel work with 215mm clutch? The reason i asked is i found an affordable light flywheel compared to Fidanza 215mm flywheel. was thinking if its ok or safe to match them together.
2. i was told that single/multi plate clutch kit does not release as much HP as the normal single clutch kit. Is this true?
my setup is a 7age 20v. im not sure if the 200mm + light FW is better or less performance than 215mm + oem FW.
thanks
morgan
Re: 4A 7A Clutch Question
Postby morgan » Fri Feb 27, 2015 11:26 am
don't mix and match the 200 & 212mm, and keep in mind that the 7AFE is a 6 bolt flywheel, while the 4AGE is 8. 4AC is 6, as well as the 4AFE.
My turd of an 86
20v swapped 86 write-up
speedmaster
Postby speedmaster » Fri Feb 27, 2015 2:45 pm
My 7a flywheel is 6 bolt 215mm
morgan
Postby morgan » Fri Feb 27, 2015 5:57 pm
I was hnaware the 7afe was 2-5mm, im used to hearing 200 & 212 for the 4age's. Regardless, dont mix and match different size clutch and flywheels
My turd of an 86
speedmaster
Postby speedmaster » Sun Mar 01, 2015 6:53 am
morgan wrote:I was hnaware the 7afe was 2-5mm, im used to hearing 200 & 212 for the 4age's. Regardless, dont mix and match different size clutch and flywheels
maybe its 212mm my bad
is there and HP loss if i switch from 212 to 200mm?
Toy86
Postby Toy86 » Mon Mar 02, 2015 1:19 am
I don't think you lose/gain any hp by changing to a different diameter flywheel.
I think the only thing that might change is torque band, since going to a smaller lighter flywheel will cuz the engine spin faster and give you better throttle response.
That's why ppl go with lighter flywheels so the engine has to use less force to get to the power band faster. This is just my theory.
I'm sure there are ppl on here that can break down the dynamics and engineering verbiage of how this works.
speedmaster
Postby speedmaster » Mon Mar 02, 2015 1:21 am
Make sense.
Jimmee1990
Postby Jimmee1990 » Sun Apr 05, 2015 8:29 pm
The diameter of the flywheel itself between 200mm and 215mm set ups is the same, it's only the friction face diameter that's different. You won't lose or gain anything going between the two with power, torque or inertia. Just have more clamping area using a 215mm clutch and flywheel.
Also no difference in power between single and multi plate clutches, just more clamping area again.
speedmaster
Postby speedmaster » Tue Apr 14, 2015 3:43 pm
Jimmee1990 wrote:The diameter of the flywheel itself between 200mm and 215mm set ups is the same, it's only the friction face diameter that's different. You won't lose or gain anything going between the two with power, torque or inertia. Just have more clamping area using a 215mm clutch and flywheel.
thank you jimmee
