injector help
injector help
so guys i am getting all the odds and end together to reassemble my 86 4age motor and one of the things i was going to replace is the injectors and guess what the guys at yota have done, they have discontinued the series of injectors so does anyone have a brand of injectors they know/trust that i can get to run a stock fuel pump rail and will not be a problem with my stock computer
									1966 mustang (my lover)
2006 f150 (my regular)
1986 gts Corolla (my affair)
Re: injector help
Send your injectors out to a reputable shop like RCI or Witchhunter to be cleaned. If any of your injectors are beyond help peeps here have spares sitting around. I know I have 16 or 20 of them.
									One shot, one kill.
						Re: injector help
Ive heard of Honda d17injectors being used. Don't quote me on that though.   But yeah you can clean your originals
						Re: injector help
I did some research last year and it seems that the 85 & 86 Camry and the 7MGE Cressida and Supra use a low impedance injector in the 185-195 cc/min range, so that might be helpful if you can find some in a junkyard.
									ariel_86 wrote:After some research, I got lucky at the junkyard and pulled two sets of injectors from a 1985 and 1986 Camry. These beige injectors are low impedance and rated at 185 cc/min, close enough to 190 for my car.
They even fit in the fuel rail!
I remembered to get the connectors, too.
1985 Toyota Corolla Sport GTS - Ariel - 105.5 whp 93.8 ft-lbs  of torque
2006 Toyota Tacoma SR5 V6 6MT - mmm, taco!
2006 Mitsubishi Lancer ES 5MT - 2slow
Re: injector help
Are the injectors in the '86 that low in flow? I thought they were the same through '87, 210cc min flow.
									One shot, one kill.
						Re: injector help
I have no idea but I just wanted to get new injectors for the car. So I did and I put it all back together and now it will run fine like a top but as soon as it gets warm it starts to bog down until death. I got remanned injectors if that means anything and any ideas on what is going on
Re: injector help
So my car will run for a min or so but it will pop like there is a small vac leak or something. Then out of nowhere almost it starts to bog down and then go back to idle. It will do that a series of times then die and if I start it back right after it does this it will bounce rpm up and down and then die
Re: injector help
Check your fuel pressure, should be around 43 PSI, I would also change the fuel filter and a really good check of the vacuum hoses. Dave W
				Illegal_Garage
Re: injector help
did you check for any error codes?
Max
									Max
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
Maxfrommisawa@aol.com
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
Re: injector help
the only code i have is #6 rmp or crank angle pulse. it is running fine now i have the old injectors in it now because they checked out okay. so what do i do now that i am popping a code
