Megasquirt or other aftermarket ECU - check engine light?
Rogue-AE95
Postby Rogue-AE95 » Fri Jul 25, 2014 2:38 pm
Was just wondering if it's possible to retain a check engine light (CEL) when using any of the aftermarket ECUs? They must be able to tell when a sensor is going bad, or if it's getting bad readings due to a bad tune. I was hoping that an aftermarket ECU can be hooked up to the dash CEL so that you can know right away if there's a problem while driving.
And what about something like the brake & battery indicators going off due to a bad alternator? Is there any way to keep that when you run with an aftermarket ECU?
burdickjp
Re: Megasquirt or other aftermarket ECU - check engine light
Postby burdickjp » Fri Jul 25, 2014 7:04 pm
Rogue-AE95 wrote:Was just wondering if it's possible to retain a check engine light (CEL) when using any of the aftermarket ECUs? They must be able to tell when a sensor is going bad, or if it's getting bad readings due to a bad tune. I was hoping that an aftermarket ECU can be hooked up to the dash CEL so that you can know right away if there's a problem while driving.
Brake and Battery indicators are separate of the ECU, so that'll work no matter what.
I don't remember about the Megasquirt 2, but the Megasquirt 3 has a method of determining if a sensor is faulty, going into a limp mode, and triggering a light. It's really cool, actually, but involves a LOT of tuning to get right.
Pursuing the ideal
Postby jondee86 » Sat Jul 26, 2014 3:46 pm
To be able to monitor for a bad (out of range) sensor input, the ECU would
have to know the expected sensor range. Easy enough for a factory stock car
with factory sensors and factory ECU. Not so easy when the ECU supplier does
not know what car the ECU will be fitted to, and what type/range of sensors
are used.
Probably why serious race cars are fitted with a full array of gauges to show
operation critical values for temperature, pressure, knock, AFR etc.
If you seriously wanted a CEL, you would need an aftermarket ECU with a lot
of aux inputs and connect up a bunch of sensors to everything that you want
to monitor. Program the ECU to trigger an aux out for the CEL each time a
sensor reading goes high (temp) or low (pressure). If you had two different
tunes, you could have the ECU switch tunes when the CEL output turned on.
I have a very simple ECU and I use it to switch my electric cooling fan on/off
according to the reading of the EWT. With a sophisticated ECU there are a
lot more programming (logic) options.
Rogue-AE95
Postby Rogue-AE95 » Sun Jul 27, 2014 10:56 am
Thanks guys. Looks like I have more reading up to do on aftermarket ECUs. Using a chipped Honda ECU seems to have a few advantages in this regard, although it would also be a bit complicated to set up.
burdickjp
Postby burdickjp » Sun Jul 27, 2014 2:29 pm
Rogue-AE95 wrote:Thanks guys. Looks like I have more reading up to do on aftermarket ECUs. Using a chipped Honda ECU seems to have a few advantages in this regard, although it would also be a bit complicated to set up.
To be honest, I've never found a CEL necessary with an aftermarket ECU. It's really easy to diagnose sensors, injectors, coils, etc. when you have as much control and flexibility as a fully programmable ECU provides.
Pursuing the ideal
Postby jondee86 » Mon Jul 28, 2014 11:27 pm
Here ya go... http://www.adaptronic.com.au/the-basic- ... functions/
Postby MisterJerk » Wed Jul 30, 2014 12:41 pm
burdickjp wrote:To be honest, I've never found a CEL necessary with an aftermarket ECU. It's really easy to diagnose sensors, injectors, coils, etc. when you have as much control and flexibility as a fully programmable ECU provides.
I bet he needs a working(or appears to be working) CEL for inspection/emissions/registration purposes.
MSPNP owners: does the CEL come on? or can it be triggered via the ecu somehow?
Inquiring minds wanna know.
Rogue-AE95
Postby Rogue-AE95 » Wed Jul 30, 2014 3:10 pm
Very cool, thanks for that link!
Thankfully I don't have inspections to deal with, but if I move someday and have to deal with them, I would need a workaround. I do like having a "dummy" light to let me know something is not kosher in the engine bay. If a sensor fails, like air intake temp, you could have problems with your tune but never know it (because who is going to have a gauge relating to every sensor?). But instead of having to stick a jumper in a diagnostic connector and goof around with codes, you just check your ECU with a laptop (or however you check data logging). Better than OBD-II... ;)
jmaz87
Postby jmaz87 » Wed Aug 27, 2014 6:10 pm
the latest Megasquirt3 firmware uses code based CEL so it actually blinks like the stock car did telling u what is wrong which for me is awesome and yes i use it!
the result is all of my warning lights are still fully functional as are my gauges. but i still run a tablet on shadowdash because it too is awesome!
Tuneshttps://truck.it/p/1Dl1ejMkZq
85' AW11 MS3/X Full Sequential w/ COP (DD)
87' AW11 Spare Shell
88' FJ62 MY BABY
91' AE92 DX Gutted, caged, @15psi GRMS challenger
91' AE92 DX Spare Shell
94' AE101 7AFE Backup DD
03' CBR 954 RR FireBlade
Rogue-AE95
Postby Rogue-AE95 » Thu Aug 28, 2014 3:23 pm
jmaz87 wrote:the latest Megasquirt3 firmware uses code based CEL so it actually blinks like the stock car did telling u what is wrong which for me is awesome and yes i use it!
Very cool... thanks.
