20v auto ecu or 5 speed?
i had a couple of ecus sitting around so i decided to try them all, couldnt find any real differences between the auto ecu and the manual 5 speed one... seems to run a bit richer around 2200 - 3200 rpms and redline seems to be about the same. does anyone have any confirmed information about this?
Re: 20v auto ecu or 5 speed?
ive read numerous times the the auto ecu has a slightly higher rev cut, maybe 250rpms more, and the map might be slightly different because of the intended shift points for the transmission
My turd of an 86
20v swapped 86 write-up
My turd of an 86
