lightend flywheel for 7ag
Spoold86
Postby Spoold86 » Thu Feb 20, 2014 7:37 am
200m or 212mm just looking for a company that makes lightened 6 bolt flywheels of if anyone has one
Re: lightend flywheel for 7ag
Postby yoshimitsuspeed » Thu Feb 20, 2014 10:17 am
There are none currently made but you are the third person in about as many months to ask. I just emailed Fidanza and ACT to see if they would be able to make one.
jdm86gtz
Postby jdm86gtz » Fri Feb 21, 2014 5:47 am
Could you cut an OEM 7A flywheel to the same design as a Blacktop 20V flywheel.
Just thinking for the future for my 7A build.
Jeff Lange
Postby Jeff Lange » Fri Feb 21, 2014 11:13 am
Best bet would be to contact a company already making 4AG flywheels and ask about the possibility of getting it blank/drilled with 6-bolt. I'm sure someone out there can/would do it for you.
Jeff
Postby yoshimitsuspeed » Fri Feb 21, 2014 11:29 am
Jeff Lange wrote:Best bet would be to contact a company already making 4AG flywheels and ask about the possibility of getting it blank/drilled with 6-bolt. I'm sure someone out there can/would do it for you.
Jeff
I emaild Fidanza yesterday but still haven't heard back.
I emailed ACT and told them they should make a FW for the GE and FE. They told me they were going to throw the idea to the R&D dept. I doubt they will think there is the demand.
I don't think Exedy would be worth it. They are a PITA to deal with and operate on the massive corporate structure when it comes to adding or making changes.
I couldn't think of any other big name brand companies off the top of my head.
