blue & brown VSV
xarion
blue & brown VSV
Postby xarion » Mon Jun 09, 2014 5:26 am
I bought a 4AGZE engine where the black cylinder part of my brown VSV has broken off (not sure what that is). I will be doing the ABV mod which essentially removes the blue VSV, could I use this blue VSV in place of the brown one, (wont look so hot because of the brown connector going on the blue vsv) could this be done or should I start looking on ebay for a brown vsv?
jdm86gtz
Re: blue & brown VSV
Postby jdm86gtz » Mon Jun 09, 2014 8:41 am
I did away with both VSVs and piped the Fuel Pressure Regulator directly to the manifold.
The blue VSV might have a tab that would prevent the brown connector to fit but this can be filed down to allow the connector to fit.
xarion
Postby xarion » Mon Jun 09, 2014 11:23 am
Thanks, I think I'm going to do the same thing as I cant seem to find the OEM ecu anywhere on the net. Did you also do away with the solenoid valve for air bypass for the S/C?
jdm86gtz
Postby jdm86gtz » Mon Jun 09, 2014 2:07 pm
I kept that one piped up and connected to the ecu.
xarion
Postby xarion » Tue Jun 10, 2014 12:55 am
Thanks, at what poing did you configure the ECU to engage the solenoid and for how long?
jdm86gtz
Postby jdm86gtz » Tue Jun 10, 2014 5:00 am
It's the oem ecu so it works as Toyota intended
xarion
Postby xarion » Tue Jun 10, 2014 11:00 am
I see, seems like the one pipe of the solenoid is also broken, any idea what it is called? Ebay just seems to give me the blue and brown vsv's
morgan
Postby morgan » Tue Jun 10, 2014 1:29 pm
show me where its located on the motor or better yet, give me a part #. I can see if theres any other cars that use that same sensor. you would be surprised the amount of sensors Toyota uses on numerous cars.
My turd of an 86
20v swapped 86 write-up
xarion
Postby xarion » Wed Jun 11, 2014 2:43 am
found the model number and its called an ACV - 25740-16020, going to go see what my local depot is going to charge me...
http://opc.mr2oc.com/online_parts_catalog/Engine/vacuum%20piping.GIF item marked 23275 Valve in the bottom/middle right
morgan
Postby morgan » Wed Jun 11, 2014 3:39 am
Its 4agze only and not available new anymore. Sorry
My turd of an 86
