Cylinder 3 spitting?
kennyb01
Postby kennyb01 » Fri Feb 01, 2013 10:29 am
Hey guys, story is I rebuilt the block because oil was getting past the rings and had a bit of blow by. The engine ran fine before that. It's a 16 valve with weber 45 dcoe carbs. I set timing, wired up the msd, and started it up for the initial break in. But for some reason cylinder 3 spits periodically and inconsistently out of the velocity stack. The only thing I replaced in the carb is the valve for the floats (it was stuck shut and wouldn't fill the bowl) I replaced the gasket on that top plate since it leaked fuel. I haven't touched the idle air screws only adjusted idle. Any ideas as to why it would be doing this? Ps. Carbs were obviously tuned prior to teardown.
allencr
Re: Cylinder 3 spitting?
Postby allencr » Fri Feb 01, 2013 2:06 pm
What's the compression?
I don't know what that means, probably that the jetting is OK, but they have to be synchronized and their idle mixture has to be adjusted, there are no options.
Postby yoshimitsuspeed » Sat Feb 02, 2013 9:20 am
Is there any possible way you have a sticking valve or maybe a tight shim? I can't think of too many reasons why it would do what you describe but a leak on the compression stroke blowing air back out the intake seems about as logical as anything.
kennyb01
Postby kennyb01 » Sat Feb 02, 2013 6:43 pm
Thanks guys, things I've considered but wanted a second opinion. I was really hoping I could cheat and not have to re-tune the carbs. Lol I'll double check compression and for a sticky valve as well.
