how to install AFPR on 20V (BT)
onnaj
Postby onnaj » Wed Jul 10, 2013 4:58 am
Hello,
I want to install an adjustable fuel pressure regulator on the 4AGE 20V Blacktop, mainly so i can check the actual fuel pressure, but i like to be able to adjust it.
I don't know how to exactly install it. I think the stock FPR falls in the hole of the fuel rail on one side and has a special oring. On the other side it has the fuel return hose attached and ofcourse the vacuum hose.
Someone has good tips how to best install it?
Thanks
ga_goosh
Re: how to install AFPR on 20V (BT)
Postby ga_goosh » Thu Jul 11, 2013 5:14 pm
it all depends on what fpr you choose. here is one for a b&m fpr from dr occa
http://www.86garage.com/forums/viewtopic.php?f=47&t=1664
I <3 my AE86
4AG Manual
AE86 FSM
onnaj
Postby onnaj » Fri Jul 12, 2013 3:12 am
I've ended up buying an adapter for the fuel rail.
The one one the picture is for the Honda i believe, the one from Toyota has a bigger tube (don't know the right word in english for this) where you put it in the fuel rail.
Maybe i'm going to fit it this afternoon, so i'll let you guys know if it'll work.
Thanks
onnaj
Postby onnaj » Mon Jul 15, 2013 12:10 pm
FYI -> the adapter works. Had to adjust it a little bit to make more room for the screws.
Unfortunately is the AFPR i bought not working :( So kept it stock.
choi0706
Postby choi0706 » Tue Jul 16, 2013 8:09 am
part number on that adapter ?
onnaj
Postby onnaj » Tue Jul 16, 2013 9:14 am
It's called the D1 Spec Fuel Pressure Regulator Adapter for Toyota. As mentioned you have to adapt it a little bit to make the screws fit the holes.
It costs about 13 dollar i think, here is the webaddress: http://www.fullcartuning.com/45359/D1-S ... or-Adapter
onnaj
Postby onnaj » Tue Jul 16, 2013 11:43 am
Or buy this one: http://www.ebay.nl/itm/Toyota-Corolla-M ... 1e7b92ca59
Think that one doesn't need to be adapted ;)
choi0706
Postby choi0706 » Thu Jul 18, 2013 9:03 pm
geez shipping is really killer.. any way you can drop it in a flat rate box or envelope?
this is bolt on, correct? no modifying..
Postby yoshimitsuspeed » Fri Jul 19, 2013 10:50 am
choi0706 wrote:geez shipping is really killer.. any way you can drop it in a flat rate box or envelope?
I don't have them in stock so either I ship them straight from my distributor or have to add the shipping cost getting them to me and then shipping them out to customers.
Unfortunately my distributor doesn't have a lot of shipping options and I could probably ship you 10 for the same cost as one.
That said I am still dialing in my shipping calculator on my website. What was the quote and where are you located?
choi0706 wrote:this is bolt on, correct? no modifying..
I just recently found these and haven't sold one or tried one yet but yes they should be bolt on with no modification.
choi0706
Postby choi0706 » Mon Jul 22, 2013 2:22 pm
16.41 to business address in Sealy , TX 77474
Postby yoshimitsuspeed » Mon Jul 22, 2013 7:53 pm
choi0706 wrote:16.41 to business address in Sealy , TX 77474
Oh my, lol. Thanks for the heads up.
I will try to play with the shipping settings tomorrow.
If you want you can send $32 via paypal to yoshimitsuspeed at matrixgarage.com with the part number and shipping addy.
Otherwise I'll post back up here after playing with my shipping settings.
choi0706
Postby choi0706 » Mon Jul 22, 2013 10:12 pm
paypal sent
Postby yoshimitsuspeed » Tue Jul 23, 2013 12:54 pm
choi0706 wrote:paypal sent
Order processed.
choi0706
Postby choi0706 » Thu Aug 08, 2013 5:05 pm
was it shipped out?
Postby yoshimitsuspeed » Fri Aug 09, 2013 12:16 pm
choi0706 wrote:was it shipped out?
It shows delivered on the 26th. I'll PM you the tracking no and make sure I got the right addy and everything.
