Question about gaskets from overhaul gasket kit
onnaj
Postby onnaj » Fri Apr 05, 2013 1:26 pm
Hello,
Can someone tell me what the gasket with number 1,2,3 and 4 are for? Thanks ;)
ga_goosh
Re: Question about gaskets from overhaul gasket kit
Postby ga_goosh » Tue Apr 09, 2013 12:53 pm
is this for a 20v or a 16v?
is 2 and 4 the same size? these could be the fuel hose to fuel rail seals. 1 is for the water pump backing plate o ring seal. 3 i dont know what that is for
I <3 my AE86
4AG Manual
AE86 FSM
Rogue-AE95
Postby Rogue-AE95 » Tue Apr 09, 2013 1:30 pm
Could 1 be the oil dipstick tube? It looks kind of small to be the water pump backing plate, at least comparing it to the valve stem seals. 2 & 4 do look like crush washers for the fuel hose banjo bolt or the cold start injector.
Is 3 made of papery stuff?
ga_goosh
Postby ga_goosh » Tue Apr 09, 2013 2:43 pm
Rogue-AE95 wrote:Could 1 be the oil dipstick tube? It looks kind of small to be the water pump backing plate, at least comparing it to the valve stem seals. 2 & 4 do look like crush washers for the fuel hose banjo bolt or the cold start injector.
yea i was originally thinking the dipstick tube too so yea it could be.
I <3 my AE86
4AG Manual
AE86 FSM
onnaj
Postby onnaj » Wed Apr 10, 2013 12:14 am
Hello,
The gasket kit it for the 20V indeed.
I think nr1 has to be the oil dipstick tube then (size is about 13.7mm (0,5314 inch). The water pump o-ring has been used already ;) I think the one for the waterpump is brown and about 40 mm (1,5748 inch).
2 and 4 are the same size about 16mm (0,6299 inch).
3 is a sort of paper thing yes and it meausures 21mm (0,8267 inch)
onnaj
Postby onnaj » Wed Apr 10, 2013 12:21 am
Hello,
carbd7age
Postby carbd7age » Wed Apr 10, 2013 7:58 am
Are those measurements the outside diameter?
1. Dipstick
2. Fuel banjo
3. Drain plug
4. Fuel banjo
Knockoff Crew member #0001
onnaj
Postby onnaj » Wed Apr 10, 2013 10:47 am
I've meausured the outside diameter yes.
No wonder i didn't recognise the drain plug gasket, cause i bought a new oil pan with the plug already in it. :-)
Thanks all.
