jdm smallport pn's needed
Jeonsah
Postby Jeonsah » Sat Mar 09, 2013 9:19 am
Hey guys,
Simply put I have a 16v smallport with a jdm smallport harness from a ae92. I am missing the map sensor. So basically I just a few compatible parts with #'s.
I need to know what the part numbers are for:
1. map sensor (or any other that will work)
2. Distributor cap & rotor (it is the jdm dizzy)
I have asked for this information a long time ago but I lost all the data on my computer. If anyone could help out, that would be great!
Thanks
Deuce Cam
Re: jdm smallport pn's needed
Postby Deuce Cam » Sat Mar 09, 2013 3:28 pm
I'm not positive, but I think you can use the map sensor from a '91 corolla gts (smallport 4age) or a '91 corolla w/ 4afe (mine is map equipped).
Jeonsah
Postby Jeonsah » Sat Mar 09, 2013 9:44 pm
these are cars in the united states correct?
Rogue-AE95
Postby Rogue-AE95 » Mon Mar 11, 2013 4:14 pm
I think people have used the 90-92 Corolla (4A-FE) MAP sensors with their 20v Blacktops. Same connector. Not sure about the JDM 16v smallport.
Deuce Cam
Postby Deuce Cam » Mon Mar 11, 2013 4:54 pm
Jeonsah wrote:these are cars in the united states correct?
I forgot the usdm small port 4age was also afm so that won't work.
My '91 corolla le with 4afe has the map based setup though. I can pull the part # off the map sensor if you want.
morgan
Postby morgan » Tue Mar 12, 2013 12:01 pm
Vic, didnt i give you access to toyodiy? you can look up the p/n's there...then do a reverse lookup to see what else they are on, in all countries.
My turd of an 86
20v swapped 86 write-up
Jeonsah
Postby Jeonsah » Tue Mar 12, 2013 8:02 pm
Thanks morgan. I totally forgot about Toyodiy.... it got me everything + more than what I needed!
