OST-054: 3 rib with snap
Postby oldeskewltoy » Wed Jan 09, 2019 3:17 pm
OST-054's owner is "local" (no shipping). The first head he brought to me, back in early December, had seen an "attempt" at changing the squish pads :cry: He had bought the head a few years ago as the one he would build - he wasn't too happy once I showed him the flaw
At this time I'd like to STRONGLY recommend that if you "try" to port a head, and you don't know what you are doing... STOP. In the past 3 years I've bought 3 heads that had to be scrapped because of very poor "attempts"..... that ruined the casting :evil: If you are going to try... just make sure that head isn't sold on.......
So my client disassembles his engine to get me his current head... and it too has seen a hand inside it. On this one it wasn't "fatal"..... the roof of the port has seen some "work"... along with a lot of "smoothing" inside the exhaust port.
This type of work (tapering port roof) I try to reserve for ITB equipped heads to try and and match the angle of the ITB adapter. In this case some care was used by the previous "porter" so that this head could be re-used.
disassembled, prior to cleaning
This head has been machined once as well
more to come.... :D
Re: OST-054: 3 rib with snap
Postby oldeskewltoy » Fri Jan 11, 2019 3:36 pm
from another forum wrote:what should the head size be if it hasn't been machined before?
116mm
work begins..... #4 on the left...
Oh... as the title states... this is a 3 rib, and my client manage to find a set of high comp TVIS pistons 13103-16030, the same pistons I used in OST-050.
His short block is being built at a local machine shop - with my technical assistance.
more to come..... :D
Postby oldeskewltoy » Sat Jan 12, 2019 1:47 pm
from another forum wrote:Short turns look beautiful.
and #3 and #2
Postby oldeskewltoy » Mon Jan 14, 2019 2:06 pm
Intake side finished... on to the exhaust side and the chambers....
more to come.... :D
Postby oldeskewltoy » Wed Jan 16, 2019 10:10 am
3 down so far.....
more to come.... :D
Postby oldeskewltoy » Thu Jan 17, 2019 4:47 pm
oldeskewltoy wrote:3 down so far.....
and now the exhaust side is done.....
and from a slightly different perspective...
Next is getting the chambers deshrouded.....
