OST-045: 5AGTE.... again ;)
Postby oldeskewltoy » Wed Jan 17, 2018 2:44 pm
As arrived. The head has been cleaned, but I don't know if it has also be pressure tested, so I'll be sending it out, along with all the associated bits to get cleaned and pressure checked before I start work.
The buckets and shims have seen better days... replacing them with good used units is far less costly then trying to salvage these
More to come....... :mrgreen:
Rogue-AE95
Re: OST-045: 5AGTE.... again ;)
Postby Rogue-AE95 » Wed Jan 17, 2018 3:50 pm
1.7l?
How did those shims get what appears to be rust on them??
Postby oldeskewltoy » Fri Jan 19, 2018 10:01 am
Rogue-AE95 wrote:1.7l?
somewhere over 1.7 liters... final size depends on their overbore.
rusty shims - Now sure... the head came to me cleaned, but everythjing else just came in a box. The shims, and the buckets carry a moderate level of rust, so these items will be replaced.
work begins.... de-burring the casting......
more to come...... :D
Postby oldeskewltoy » Mon Jan 22, 2018 6:19 pm
working the first set of bowls and seats.....
more to come....... ;)
Postby oldeskewltoy » Wed Jan 24, 2018 3:54 pm
2 down.... 2 to go....
Postby oldeskewltoy » Fri Jan 26, 2018 10:35 am
Just about done on the intake side.........
more to come..... :D
Postby oldeskewltoy » Fri Jan 26, 2018 4:40 pm
next... the exhaust side....
more to come........ :D
Postby oldeskewltoy » Wed Jan 31, 2018 2:16 pm
Chamber work has begun.....
more to come....... :D
Postby oldeskewltoy » Mon Feb 05, 2018 12:47 pm
3 chambers down......
sometimes the right tool is the simplest.... working the chamber wall with 120 grit. ;)
more to come.... :D
Postby oldeskewltoy » Thu Feb 08, 2018 7:50 am
Chambers done...... (for now)
work begins on the exhaust side.... one done... one under construction
Rogue-AE95
Postby Rogue-AE95 » Thu Feb 08, 2018 6:21 pm
That's a lot of material in the one port :!:
Postby oldeskewltoy » Fri Feb 09, 2018 10:08 am
Rogue-AE95 wrote:That's a lot of material in the one port :!:
with a lot more to remove!
2 down... 2 to go
more to come.... :D
kaosboss
Postby kaosboss » Sat Feb 10, 2018 3:37 pm
Looking good....keep the pictures coming.
Postby oldeskewltoy » Sun Feb 11, 2018 10:47 am
kaosboss wrote:Looking good....keep the pictures coming.
Ready for her multi angle......
Postby oldeskewltoy » Thu Feb 22, 2018 9:24 am
back from her multi angle....
more to come.... :D
aukword1
Postby aukword1 » Thu Feb 22, 2018 12:34 pm
looks very clean! Always, enjoy looking at your threads. What size cams are going into this?
mr2mk1hero
Postby mr2mk1hero » Fri Feb 23, 2018 1:09 am
Amazing work as always. How the heck do you get those shallow coolant passages around the chambers so clean?
Postby oldeskewltoy » Fri Feb 23, 2018 7:23 am
mr2mk1hero wrote:Amazing work as always. How the heck do you get those shallow coolant passages around the chambers so clean?
One of the costs.... I have each head cleaned and pressure checked at a machine shop. In this case the head did come to me cleaned already, but I still had it checked for its pressure holding capability.
aukword1 wrote:looks very clean! Always, enjoy looking at your threads. What size cams are going into this?
This engine is getting a set of Cat cams 262, 230@ .050", with 9mm lift
Rogue-AE95
Postby Rogue-AE95 » Fri Feb 23, 2018 4:07 pm
I always like these topics, even if I don't post in them much. Great work as always :idea:
Postby oldeskewltoy » Sat Feb 24, 2018 2:44 pm
Rogue-AE95 wrote:I always like these topics, even if I don't post in them much. Great work as always :idea:
thank you kind sir.........
moving on....
Chambers currently @ 37cc. Now to decide what the final volume is to be, and then machine the surface to size. This head has not been machined since it left Toyota. Once machined we can move on to assembly, and fitting the cams.
more to come.... :D
mr2mk1hero
Postby mr2mk1hero » Mon Feb 26, 2018 5:59 am
The machine shop that does the work is seriously impressive then. I took two heads so far to two different machine shops and neither could get the coolant passages as spotless as this.
Postby oldeskewltoy » Sat Mar 10, 2018 2:27 pm
Not all of the heads I work have this "pretty" of a finish from cleaning...
BUT... all heads leaving are machined so that you can read in their reflection... OR more appropriate - fully ready for a metal head gasket!
More to come........ :D
Postby oldeskewltoy » Mon Mar 19, 2018 8:37 am
ready for assembly.... with a pair of Cat camshafts
more to come......... :D
Davegt27
Postby Davegt27 » Tue Mar 20, 2018 8:42 am
I put bigger valves in my 5AGZE head
Not sure if it was a good idea or not
(Some call it a 5.5ge)
Davegt27 Code One Racing
Postby oldeskewltoy » Tue Mar 27, 2018 11:15 am
Davegt27 wrote:I put bigger valves in my 5AGZE head
The first 2(5AG) I've done I did with std valves... I MAY be working another one ... and that one the client is discussing running larger valves. Why are you unsure of your decision???
The head is getting shipped back to my client....
For shipping: :ugeek: With cam dummies in I can keep the shims I want in place without having the cams installed..... ;)
Rogue-AE95
Postby Rogue-AE95 » Tue Mar 27, 2018 4:43 pm
That's a good idea! I know I've been saying this for years, but I look forward to sending you a 4A-GE head for work. It's all in the details like that ^
Davegt27
Postby Davegt27 » Thu Mar 29, 2018 2:22 am
I can't report any big power gains for the added expense
Sorry for the late post I forgot about this thread
