hey to all i am start on build my friend engine for rolla i will make 7agze
7afe block with sc 14 and head 4age big port i think its a little bit storng so i need to know what starter i will need ??
oem ae86 i think is waek with this engine its much power
i heard from ae92 fit it on corolla trans
what about 1g what is this starter ??
any ideas ??
build 7agze sc14 what strater ??
Re: build 7agze sc14 what strater ??
stock starter is fine.
Evo_lucian wrote:stock starter is fine.
hi you mean 7afe ??
i will go about 250-300ps is this starter good enougth ??
i want to go with w58 trans ( t50 is weak as we know ) i want to use 225-230mm flywheel from 4agze
i have ( all engine ) from 4agze ae92 can i use it ??
crazyae86 wrote:Evo_lucian wrote:stock starter is fine.
hi you mean 7afe ??
The starter couldn't care less how much power the motor makes.
Compression is the only thing that will effect the starter so a 180 WHP high comp build would be more load on the starter than a 500 hp turbo low comp build.
Use whatever starter fits the bellhousing you are using.
yoshimitsuspeed wrote:The starter couldn't care less how much power the motor makes.
yoshimitsuspeed wrote:crazyae86 wrote:Evo_lucian wrote:stock starter is fine.
hi you mean 7afe ??
Agreed.
